Home » Eclipse Projects » Mylyn » Bugzilla Connector and Target Milestone
Bugzilla Connector and Target Milestone [message #46600] Fri, 04 April 2008 10:35 Go to next message
Originally posted by: mauro.molinari.cardinis.com
Hello all!
I just noticed that with Mylyn 2.3.1, I can't change the Target
Milestone field in our internal Bugzilla 2.18 installation tasks using
the built-in editor. The problem is that the Target Milestone field is
rendered as a simple edit box, instead of a combo box with all the
available values...
I'm sure in the past I had no problem with that. The workspace I'm using
has tasks and repositories imported from a previous one: could be this
the main problem? I tried to do an "update attributes" on the task
repository, but this didn't help.
Any hint?
Mauro.
Re: Bugzilla Connector and Target Milestone [message #46624 is a reply to message #46600] Fri, 04 April 2008 10:38 Go to previous messageGo to next message
Sorry, I fixed the issue right now...
I did an "update attributes", then closed and reopened the task editor,
but it was not enough. I had to refresh the task with "synchronize
incoming changes" in order to get the Target Milestone combo box
populated...
Maybe as a user I would expect that "update attributes" on the task
repository should update the currently open task editor view...
Mauro.
Re: Bugzilla Connector and Target Milestone [message #46693 is a reply to message #46624] Fri, 04 April 2008 21:35 Go to previous messageGo to next message
Originally posted by: rob.elves.eclipse.org
Agreed! There may be some tricky side effects due to dirty editor state
etc, but please post a new bug report for this Mauro.
-Rob
> populated...
> Mauro.
Re: Bugzilla Connector and Target Milestone [message #46953 is a reply to message #46693] Thu, 10 April 2008 03:40 Go to previous message
> -Rob
Hi Robert,
here it is, thank you!
https://bugs.eclipse.org/bugs/show_bug.cgi?id=226449
Mauro.
Re: Bugzilla Connector and Target Milestone [message #588903 is a reply to message #46600] Fri, 04 April 2008 10:38 Go to previous message
populated...
Mauro.
Re: Bugzilla Connector and Target Milestone [message #588911 is a reply to message #46624] Fri, 04 April 2008 21:35 Go to previous message
-Rob
> populated...
> Mauro.
Re: Bugzilla Connector and Target Milestone [message #589023 is a reply to message #46693] Thu, 10 April 2008 03:40 Go to previous message
> -Rob
Hi Robert,
Mauro.
Previous Topic:Mylyn 2.3.2 is now available / new update site for ganymede
Next Topic:Store personal settings into Mylyn for my own connector
Current Time: Tue Jul 22 02:38:55 EDT 2025
Powered by FUDForum. Page generated in 0.07274 seconds
