Home » Eclipse Projects » DTP » is there any samples for dtp consumer application ?
is there any samples for dtp consumer application ? [message #46580] Wed, 09 July 2008 05:06 Go to next message
Originally posted by: rick_murphy.sohu.com
I have a application written in java which can import data from csv file
into database. i wanna refactor it to an eclipse plugin, and i found
that maybe dtp can help me with it's open data access framework.
my plan is using ODA datasource instead of CSV reader and JDBC
connector, transport data directly between the two ODA datasets with
field mapping and some other controls.
but i am a really newbie to dtp, i even do not know how to start. i know
birt is a typical consumer application of dtp, but the birt project is
too huge to read, i need some light weight consumer application example.
something like step by step tutorial will be better.
anybody can help ? examples or related articles, any advice will be
appreciated!
Re: is there any samples for dtp consumer application ? [message #46809 is a reply to message #46580] Fri, 11 July 2008 23:32 Go to previous message
Rick,
There are some related overview info in this link:
http://wiki.eclipse.org/BIRT/FAQ/Data_Access#ODA_API_Use_Cas es
Look under the "Consuming ODA Data Sources" link.
Linda
Re: is there any samples for dtp consumer application ? [message #591905 is a reply to message #46580] Fri, 11 July 2008 23:32 Go to previous message
Rick,
Linda
Previous Topic:cant create new driver definition for derby.jar
Next Topic:Custom ODA data source, want different behavior during preview vs. actual usage?
Current Time: Thu Jul 10 01:43:37 EDT 2025
Powered by FUDForum. Page generated in 0.11394 seconds
