Home » Eclipse Projects » Eclipse Platform » Examples of supporting clipboard?
Examples of supporting clipboard? [message #46574] Fri, 23 May 2003 14:36 Go to next message
Originally posted by: purplehayz.earthlink.net
Now that I have a working Table with system properties culled from the
runtime, not eclipse, JVM, I now want to be able to select a cell and copy
the value so I can paste it into an editor (or elsewhere). Can someone
point me to an example and/or supporting material for how to make a view
support the Copy menu item (I've discovered the TableCursor class so I can
select a particular cell fine)?
Thanks and have fun! - Bob
Bob Hays, Computer Geek
"In this world you must be oh so smart or oh so pleasant. Well, for years I
was smart. I recommend pleasant."
-- Elwood P. Dowd as played by James Stewart in Harvey
Re: Examples of supporting clipboard? [message #46599 is a reply to message #46574] Fri, 23 May 2003 14:52 Go to previous messageGo to next message
Please see the snippets at
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/dev.html.
For more places to find SWT information, we maintain a list of SWT links
at:
http://www.swtworkbench.com/community/bin/index.cgi?action=l inks&cat=swt
Best,
Dave
Dave Orme
Advanced Systems Concepts
Re: Examples of supporting clipboard? [message #46749 is a reply to message #46574] Fri, 23 May 2003 14:58 Go to previous messageGo to next message
The previous post only has the information on how to actually use the
clipboard. In order to hook the copy action, you need to have your view
do something like the following inside your createPartControl() method:
IActionBars bars = getViewSite().getActionBars();
bars.setGlobalActionHandler(
IWorkbenchActionConstants.COPY,
new Action() {
public void run() {
// Put your code here
Best,
Dave
Dave Orme
Re: Examples of supporting clipboard? [message #46947 is a reply to message #46749] Fri, 23 May 2003 16:18 Go to previous message
THIS is probably what I needed! Thanks, I'd already perused the SWT pages
and samples quite a bit (that's how I learned about the TableCursor class,
for example).
On 5/23/03 1:58 PM, in article balqvs$5c8$1@rogue.oti.com, "David J. Orme"
> new Action() {
> public void run() {
> Best,
> Dave
Previous Topic:Thanks
Next Topic:JDBC problem
Current Time: Mon Jul 21 20:55:49 EDT 2025
Powered by FUDForum. Page generated in 0.03235 seconds
