Home » Archived » XML Schema Definition (XSD) » extrating imported schema from WSDL file
extrating imported schema from WSDL file [message #46527] Mon, 31 May 2004 06:33 Go to next message
Originally posted by: user.no-such-domain.com
hi Ed,
Im trying to extract the schema from http://uddi.org/wsdl/inquire_v2.wsdl
this WSDL has a schema imported from http://www.uddi.org/schema/uddi_v2.xsd
when ever I try
xsdImport.resolveTypeDefinition(xsdImport.getNamespace(),
xsdImport.getSchemaLocation());
i get an exception. i tried to have the file on local machine, and change
the path parameter accordingly but dosent seem to work. im a newbie at XSD,
i dont understand what im dong wrong.
im trying code posted on this newsgroup midified slightiy.
import java.util.Iterator;
import java.util.List;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.xsd.XSDComplexTypeDefinition;
import org.eclipse.xsd.XSDImport;
import org.eclipse.xsd.XSDSchema;
import org.eclipse.xsd.XSDSchemaContent;
import org.eclipse.xsd.XSDTypeDefinition;
import org.eclipse.xsd.util.XSDResourceFactoryImpl;
import org.eclipse.xsd.util.XSDResourceImpl;
class XSDTry {
public static void main(String args[]) {
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "wsdl",
new XSDResourceFactoryImpl());
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd",
String uri = "inquire_v2.wsdl";
ResourceSet resourceSet = new ResourceSetImpl();
XSDResourceImpl xsdSchemaResource = (XSDResourceImpl)
resourceSet.getResource(URI.createFileURI(uri), true);
Iterator resources = resourceSet.getResources().iterator();
while (resources.hasNext()) {
Resource res = (Resource) resources.next();
if (res instanceof XSDResourceImpl) {
XSDResourceImpl xsdResource = (XSDResourceImpl) res;
XSDSchema schema = xsdResource.getSchema();
List schemaContents = schema.getContents();
for (Iterator i = schemaContents.iterator(); i.hasNext();) {
XSDSchemaContent content = (XSDSchemaContent) i.next();
if (content instanceof XSDImport) {
XSDImport xsdImport = (XSDImport) content;
XSDResourceImpl xsr = (XSDResourceImpl)
resourceSet.getResource(URI.createURI(xsdImport.getSchemaLoc ation()),
false);
System.out.println(xsr);
List allTypes = schema.getTypeDefinitions();
for (Iterator i = allTypes.iterator(); i.hasNext();) {
XSDTypeDefinition typedef = (XSDTypeDefinition) i.next();
if (typedef instanceof XSDComplexTypeDefinition) {
String name = typedef.getName();
System.out.println(name);
i get an exception at:
org.xml.sax.SAXParseException: Relative URI "XMLSchema.dtd"; can not be
resolved without a base URI.
at org.apache.crimson.parser.Parser2.fatal(Unknown Source)
at org.apache.crimson.parser.Parser2.resolveURI(Unknown Source)
at org.apache.crimson.parser.Parser2.maybeExternalID(Unknown Source)
org.eclipse.xsd.impl.XSDSchemaImpl.resolveTypeDefinition(XSD SchemaImpl.java:
2109)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.resolveTypeDef inition(XSDConcr
eteComponentImpl.java:2291)
at XSDTry.main(temp2.java:37)
i also get an exception at:
in the second iteration....of the while loop
java.util.ConcurrentModificationException
org.eclipse.emf.common.util.BasicEList$EIterator.checkModCou nt(BasicEList.ja
va:1226)
org.eclipse.emf.common.util.BasicEList$EIterator.next(BasicE List.java:1173)
at XSDTry.main(temp2.java:27)
Exception in thread "main"
what could be wrong?
TIA.
PS
Re: extrating imported schema from WSDL file [message #46555 is a reply to message #46527] Mon, 31 May 2004 07:23 Go to previous message
PS,
This looks like a completely bogus use of resolveTypeDefinition which takes a
name and a namespace of a type and tries to resolve it, but you've passed it a
namespace of a schema, and a schema location, so I'm not sure what you are
expecting it to do? It sounds like maybe you just need to use
XSDSchemaDirective.getResolveSchema on the XSDImport to navigate to the imported
schema.
PS wrote:
> hi Ed,
> when ever I try
> class XSDTry {
> false);
> at
> 2109)
> at
> at
> va:1226)
> at
> TIA.
> PS
Re: extrating imported schema from WSDL file [message #587915 is a reply to message #46527] Mon, 31 May 2004 07:23 Go to previous message
PS,
schema.
PS wrote:
> hi Ed,
> when ever I try
> class XSDTry {
> false);
> at
> 2109)
> at
> at
> va:1226)
> at
> TIA.
> PS
Previous Topic:extrating imported schema from WSDL file
Next Topic:Building Editor for
Current Time: Fri Sep 12 22:16:27 EDT 2025
Powered by FUDForum. Page generated in 0.05828 seconds
