Home » Archived » BIRT » Open Report -NoCalssDefFoundError
Open Report -NoCalssDefFoundError [message #46508] Wed, 15 June 2005 12:18 Go to next message
Originally posted by: neeraja.technolog.ca
I can't open the report created from within Report Design perspective of
eclipse.(can't see BIRT perspective)
The following error message displays:
"Unable to instantiate editor:
org.eclipse.birt.report.designer.ui.editors.ReportEditor
java.lang.NoclassDefFoundError:org/eclipse/gef/commands/Comm andStack "
What is my solution to this?
Iam using Eclipse 3.0.1, BIRT 1.0.0, EMF 2.0.3, GEF 3.1.0
Any help is appreciated.
NP
Re: Open Report -NoCalssDefFoundError [message #47051 is a reply to message #46508] Thu, 16 June 2005 04:21 Go to previous messageGo to next message
Originally posted by: none.none.com
Hi ,
You need to use GEF 3.0.1. GEF 3.1 is for Eclipse 3.1, and is not supported
in BIRT 1.0.0. You can download the 3.0.1 version here:
http://download.eclipse.org/tools/gef/downloads/drops/R-3.0. 1-200408311615/index.php
Make sure to remove or disable the GEF 3.1 plugins.
David
"Neeraja" <neeraja@technolog.ca> wrote in message
news:862d6cc8407aa7263af74ef11ee957bf$1@www.eclipse.org...
> Hello,
> Thanks
> NP
Re: Open Report -NoCalssDefFoundError [message #47574 is a reply to message #47051] Fri, 17 June 2005 11:52 Go to previous messageGo to next message
I replaced GEF3.1 with 3.0.1 and the error is resolved.
But Now I see the following in my log
" !MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:2691)
at org.eclipse.swt.SWT.error(SWT.java:2616)
at org.eclipse.swt.SWT.error(SWT.java:2587)
at org.eclipse.swt.widgets.Widget.error(Widget.java:376)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:312)
org.eclipse.swt.widgets.Scrollable.getVerticalBar(Scrollable .java:223)
org.eclipse.draw2d.FigureCanvas$2.propertyChange(FigureCanva s.java:67)
java.beans.PropertyChangeSupport.firePropertyChange(Property ChangeSupport.java:333)
java.beans.PropertyChangeSupport.firePropertyChange(Property ChangeSupport.java:270)
java.beans.PropertyChangeSupport.firePropertyChange(Property ChangeSupport.java:291)
org.eclipse.draw2d.DefaultRangeModel.firePropertyChange(Defa ultRangeModel.java:60)
org.eclipse.draw2d.DefaultRangeModel.setAll(DefaultRangeMode l.java:118)
org.eclipse.draw2d.FreeformViewport.readjustScrollBars(Freef ormViewport.java:80)
at org.eclipse.draw2d.Viewport.validate(Viewport.java:358)
at org.eclipse.draw2d.Figure.validate(Figure.java:1606)
org.eclipse.draw2d.DeferredUpdateManager.validateFigures(Def erredUpdateManager.java:237)
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager.java:137)
org.eclipse.draw2d.DeferredUpdateManager$UpdateRequest.run(D eferredUpdateManager.java:62)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2572)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2301)
at org.eclipse.swt.widgets.Display.release(Display.java:2350)
at org.eclipse.swt.graphics.Device.dispose(Device.java:174)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:112)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)"
Any clue?
Thanks a lot for your response and time.
NP
Re: Open Report -NoCalssDefFoundError [message #47601 is a reply to message #47574] Fri, 17 June 2005 12:37 Go to previous messageGo to next message
Is that only an error in the log, or does it prevent you to work normally
with BIRT in any way?
Did you also remove/disable the org.eclipse.draw2d_3.1.0 plugin? Draw2d is
used by GEF, so the version of Draw2D and GEF should be both 3.0.1
What plaform are you using? Windows, Linux,..?
David
news:aac80941be1b6de0f7e14d5e14f5b45c$1@www.eclipse.org...
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Any clue?
> NP
Re: Open Report -NoCalssDefFoundError [message #49596 is a reply to message #47601] Wed, 22 June 2005 12:52 Go to previous message
Sorry for delayed reply...
I am running eclipse on Linux and the problem seems to be the Mozilla
......Mozilla 1.7 seems to be binary incompatible with the swt part of
eclipse
Followed this:
http://dev.eclipse.org/newslists/news.eclipse.birt/msg00589. html
the rest seems to be OK
Thanks once again...
Previous Topic:jsp
Next Topic:bean parameter error
Current Time: Sun Aug 31 23:53:15 EDT 2025
Powered by FUDForum. Page generated in 0.03814 seconds
