Home » Eclipse Projects » Rich Client Platform (RCP) » RCP3.2.1 & JNLP , Application doesn't launch
RCP3.2.1 & JNLP , Application doesn't launch [message #459995] Sun, 10 December 2006 20:49 Go to next message
Originally posted by: lzkbeijing.163.com
When I open the JNLP file in a browser, Java Web Start finds all the jars and downloads them and asks for the permission to start the application. But after that nothing happens.
iceland
----------------errors---------------
!SESSION Mon Dec 11 09:48:49 CST 2006 ------------------------------------------
!ENTRY org.eclipse.core.launcher 4 0 2006-12-11 09:48:49.96
!MESSAGE Exception launching the Eclipse Platform:
!STACK
at java.util.Hashtable.put(Unknown Source)
at org.eclipse.core.launcher.WebStartMain.basicRun(WebStartMain .java:58)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.WebStartMain.main(WebStartMain.jav a:40)
at com.sun.javaws.Launcher.executeApplication(Unknown Source)
at com.sun.javaws.Launcher.executeMainClass(Unknown Source)
at com.sun.javaws.Launcher.continueLaunch(Unknown Source)
at com.sun.javaws.Launcher.handleApplicationDesc(Unknown Source)
at com.sun.javaws.Launcher.handleLaunchFile(Unknown Source)
at com.sun.javaws.Launcher.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Re: RCP3.2.1 & JNLP , Application doesn't launch [message #460003 is a reply to message #459995] Mon, 11 December 2006 05:42 Go to previous messageGo to next message
Looks like it's missing a property, possibly something like 'osgi.ws' in your JNLP resources file. What does it look like? PS Posting it to EclipseZone, surround it by (xml) and (/xml) to prevent browser mangling, except using [] instead of ()
Alex.
Re: RCP3.2.1 & JNLP , Application doesn't launch [message #460030 is a reply to message #460003] Mon, 11 December 2006 21:16 Go to previous messageGo to next message
------=_Part_1360_11920891.1165889968017
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
pls see the attachment below.
Content-Type: text/plain; name=examples.jnlp.txt; charset=us-ascii
Content-Disposition: attachment; filename=examples.jnlp.txt
<jnlp
spec="1.0+"
codebase="file:/d:/temp/examples"
href="examples.jnlp">
<information>
<title>Examples RCP Application</title>
<vendor>Jerome</vendor>
<homepage href="http://www.eclipse.org"/>
<description>Examples RCP Application</description>
<icon kind="splash" href="splash.gif"/>
<offline-allowed/>
</information>
<security>
<all-permissions/>
</security>
<application-desc main-class="org.eclipse.core.launcher.WebStartMain">
<argument>-nosplash</argument>
</application-desc>
<resources>
<j2se version="1.4+" />
<jar href="startup.jar"/>
<extension
name="Examples RCP Feature"
href="features/com.ibm.csdl.guardian.examples.feature_1.0.0.jnlp "/>
<property
name="osgi.instance.area"
value="@user.home/Application Data/examples"/>
<property
name="osgi.configuration.area"
<property
name="eclipse.product"
value="com.ibm.csdl.guardian.examples.product"/>
</resources>
</jnlp>
------=_Part_1360_11920891.1165889968017--
Re: RCP3.2.1 & JNLP , Application doesn't launch [message #460041 is a reply to message #460030] Tue, 12 December 2006 04:23 Go to previous messageGo to next message
That looks OK. What about the other JNLP feature? Presumably it uses the RCP feature internally, too, and you've got an RCP feature.jnlp there as well?
Also, what OS?
Alex.
Re: RCP3.2.1 & JNLP , Application doesn't launch [message #460474 is a reply to message #460041] Thu, 21 December 2006 04:54 Go to previous messageGo to next message
Originally posted by: lucas.bigeardel.anyware-tech.com
Pb is Eclipse 3.2.1 "deploy as Feature with JNLP options" exports jars
with additional release tags like :
<plugin.name>_3.2.1.<R32x_>.I<YYYYMMDD>.jar where <R32x_> or <R321_> are
the incriminated release tags.
It causes NPE in WebStartMAin.basicRun(...) line 58.
Practically, from WebStart point of view, you may have a valid root JNLP
file and download jars to your sandbox without problem and nothing seems
to happen because of this silent exception in startup.jar.
see : https://bugs.eclipse.org/bugs/show_bug.cgi?id=168747
HTH,
- LuCaS
> Also, what OS?
> Alex.
Re: RCP3.2.1 & JNLP , Application doesn't launch [message #460634 is a reply to message #460474] Sun, 24 December 2006 04:28 Go to previous messageGo to next message
This has been fixed in the M leading build toward 3.2.2.
"lb" <lucas.bigeardel@anyware-tech.com> wrote in message
news:emdlk8$etq$1@utils.eclipse.org...
> HTH,
> - LuCaS
> Alex Blewitt a
Re: RCP3.2.1 & JNLP , Application doesn't launch [message #460675 is a reply to message #459995] Wed, 27 December 2006 04:53 Go to previous messageGo to next message
Originally posted by: sheng.clanfang.com
I've got the same problem, the same project export, works with 3.2, but
not with 3.2.1 .
As what I read, it's a bug of Eclipse 3.2.1 release, so I have returned to
the release 3.2, or you can usr 3.2.2 Milestone versions.
Sheng Fang
Re: RCP3.2.1 & JNLP , Application doesn't launch [message #460707 is a reply to message #459995] Thu, 28 December 2006 14:59 Go to previous message
Originally posted by: devals9.hotmail.com
Have you tried WebRCP. It is a framework over webstart. It works great for me.
http://sourceforge.net/projects/webrcp/
Previous Topic:Table/View size
Next Topic:DAO
Current Time: Sun Mar 16 09:54:08 EDT 2025
Powered by FUDForum. Page generated in 0.04150 seconds
