xsd plugin directory structure [message #46471] |
Fri, 28 May 2004 19:24  |
Originally posted by: cipher8000.yahoo.com
Hi Ed,
I downloaded xsd-runtime-I200405200923.zip file. when i tried to unzip it,
it has /eclipse/plugin directory structure.
but i installed eclipse under c:/myide directory. if i unzip it under
c:/myide, it doesn't directly go under c:/myide/plugins directory.
is it possible to change the zip, so that it doesn't need to have eclipse\
as the root directory?
thanks,
-muruga
Re: xsd plugin directory structure [message #46816 is a reply to message #46500] |
Wed, 02 June 2004 17:50  |
Sorry. I was refering to old eclipse build. You are right, the new eclipse
builds (3.0 M9) has a root directory called /eclipse.
thanks
-muruga
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:40B7CCB0.FC4CA7EE@ca.ibm.com...
> Muruga,
> No, we were told this is the way we are supposed to package it. When I
asked
> "What if you don't have Eclipse installed in a directory that's called
> eclipse?" I was told that isn't valid. How did you get a directory called
> myide?
> Muruga Chinnananchi wrote:
> > Hi Ed,
it,
eclipse\
> > thanks,
> > -muruga
Re: xsd plugin directory structure [message #587886 is a reply to message #46471] |
Fri, 28 May 2004 19:35  |
Muruga,
No, we were told this is the way we are supposed to package it. When I asked
myide?
> Hi Ed,
> thanks,
> -muruga
Re: xsd plugin directory structure [message #588003 is a reply to message #46500] |
thanks
-muruga
> Muruga,
asked
> myide?
> > Hi Ed,
it,
eclipse\
> > thanks,
> > -muruga
FUDForum. Page generated in 0.04101 seconds
