Re: Columns in TableView [message #459779 is a reply to message #459774] |
Tue, 16 August 2005 14:15 |
Grant Gayed Messages: 2150 Registered: July 2009 |
Hi Igor,
Assuming that I understand your question correctly, no, table items can only
flow top-to-bottom.
If you are in a read-only context then you could fake this by, for example,
showing 4 name/value pairs per TableItem (so for TableItem 0, name/value
pair 0 would occupy columns 0 and 1, name/value pair 1 would occupy columns
2 and 3, etc). However this would not make sense if your user can select
items in the table, since selection is on a per-TableItem basis, not
per-cell.
Grant
"Igor S. Zamyatin" <isz@interstron.ru> wrote in message
news:c7784e62cab1dcf5b9aaaadf6c8100b7$1@www.eclipse.org...
> Hi all!!!
> I have a TableViewer with 2 columns, for example, "name" and "value".
> I want the columns to fill all the space of the viewer. I'll try to
> explain what I mean
> Viewer should have a row of column headers like "name" | "value" |
> "name" | "value" .. (k times) .. "name" | "value" . "k" will depend on
> the viewer width and each column will continue tne previous one.
> Has Table Viewer properties or something else that allow to do that?
> Igor S. Zamyatin
> JSC Interstron
> http://www.interstron.ru
FUDForum. Page generated in 0.02316 seconds
