Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP Profiler vs WSAD profiler
TPTP Profiler vs WSAD profiler [message #4064] Thu, 27 January 2005 09:36 Go to next message
Originally posted by: kirk_wolf_nospam.mastercard.com
Can anyone describe the current functional differences between the TPTP
profiler and the WSAD profiler?
Is there any documentation on the TPTP profiler that describes how it
works (internally)? In other words, how does it instrument methods for
profiling? Does it support a sampled model, or just a tracing model?
Finally, when profiling a remote Java JVM, it is necessary to actually
start the agent controller? I understand that the agent controller can
be used to launch the application remotely, but what if you start the
remote application manually?
Kirk Wolf
Re: TPTP Profiler vs WSAD profiler [message #4446 is a reply to message #4064] Tue, 01 February 2005 16:11 Go to previous messageGo to next message
Hi Kirk,
As far as I know, there is no difference between the profiler (piAgent) in
WSAD 5.x and TPTP except that there might be bug fixes in the current TPTP
code stream.
Threre is no documentation on the internal mechanism of the profiling agent.
It uses JVMPI for collecting profiling data and uses a trace model. It
registers some handlers with the JVM to handle method entry/exit, class
load/unload, etc. It does not support a sampled model (to the best of my
knowledge). The data is pushed through shared memory for the Agent
Controller to read and transmit to the Eclipse workbench.
No matter how the JVM is started, Agent Controller has to be started because
the it is used for command dispatch as well as data forwarding.
Samson
"Kirk Wolf" <kirk_wolf_nospam@mastercard.com> wrote in message
news:ctau8m$i99$1@www.eclipse.org...
> Kirk Wolf
Re: TPTP Profiler vs WSAD profiler [message #5684 is a reply to message #4446] Fri, 11 February 2005 11:47 Go to previous messageGo to next message
Samson,
Thanks for the information, which is helpful.
I have one additional question, if I may...
The z/OS agent controller (at least the WSAD version), seems to require
that it is started as root (uid=0). Is it possible with TPTP to start
an agent controller that is running with normal priviledges on z/OS?
Kirk Wolf
Samson Wai wrote:
> Hi Kirk,
> code stream.
> Samson
>>Thanks,
>>Kirk Wolf
Re: TPTP Profiler vs WSAD profiler [message #5772 is a reply to message #5684] Mon, 14 February 2005 10:17 Go to previous message
Kirk,
Yes. You can start an Agent Controller (both WSAD and TPTP ones) without
root access. But please make sure the "config/servicelog.log" has the file
permission "666" - otherwise the user started Agent Controller cannot write
to the log.
Samson
news:420CE19B.5040200@mastercard.com...
> Samson,
> Kirk Wolf
> Samson Wai wrote:
> > Hi Kirk,
in
TPTP
> > code stream.
agent.
because
> > Samson
> >>Thanks,
> >>Kirk Wolf
Previous Topic:Tomcat won't start with Hyades' -XrunPiAgent
Next Topic:URL recording & session cookie - Trouble using WAS 6.0 test env. as opposed to Tomcat 5.0
Current Time: Sun Jul 27 08:40:06 EDT 2025
Powered by FUDForum. Page generated in 0.28208 seconds
