"unexpected end of file" build error [message #46452] |
Wed, 19 February 2003 13:35  |
When I'm compiling my project, I get several hundred "unexpected end of
file" build errors. The reason this is coming up is because at the end
of the classes, there is CVS specific information which is commented
out. For some reason, the compiler does not like this information being
there if it isn't trailed with a return character so that there is one
blank line at the end of the document. Here's some explamples:
Doesn't Work(the error will appear on the last line):
===START OF FILE
public class MyClass{
//Revision 1.1 Added class to CVS
===END OF FILE
Works Fine: (note the empty line before End of File)
===START OF FILE
===END OF FILE
Any clues on how I can get the compiler to ignore this kind of stuff?
thanks,
-Dennis
Re: "unexpected end of file" build error [message #590626 is a reply to message #46452] |
Thu, 20 February 2003 04:08  |
Forgot to mention that this only happens in "compiler compliance level" for
jdk 1.4. I need jdk 1.4 compliance for asserts we're using.
"Dennis Warren" <notrash98@hotmail.com> wrote in message
news:b30h5s$625$1@rogue.oti.com...
> ===START OF FILE
> file://Revision 1.1 Added class to CVS
> ===END OF FILE
> ===START OF FILE
> ===END OF FILE
> thanks,
> -Dennis
Re: "unexpected end of file" build error [message #590638 is a reply to message #46565] |
Thu, 20 February 2003 09:32  |
I would post this to eclipse.tools where the compiler committers are much
more likely to address the issue.
Darins
news:b323j0$7tf$1@rogue.oti.com...
for
> > ===START OF FILE
> > ===END OF FILE
> > ===START OF FILE
> > ===END OF FILE
> > thanks,
> > -Dennis
Re: "unexpected end of file" build error [message #590647 is a reply to message #46590] |
Thu, 20 February 2003 11:10  |
Thanks!
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:b32n8m$pap$1@rogue.oti.com...
> Darins
> for
of
end
being
> > > ===START OF FILE
> > > ===END OF FILE
> > > ===START OF FILE
> > > ===END OF FILE
> > > thanks,
> > > -Dennis
FUDForum. Page generated in 0.06431 seconds
