Home » Modeling » OCL » OCL Invariants on Ecore /EMF
OCL Invariants on Ecore /EMF [message #46450] Wed, 12 December 2007 12:11 Go to next message
Originally posted by: gentlemanmann.yahoo.de
Hi all,
I am not sure whether I am right here, but i hope so.
I have used EMF to generate my model and the editor which based on.
Now i want to use the org.eclipse.ocl.ecore Plugin to implement a OCL
constraint validation fucntionality against my model instances.
I have found this Tutorial on Eclipse page
( http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. ocl.doc/tutorials/oclInterpreterTutorial.html)
I think its exactly what i need but the problem ist that i get an
exception by Creating an OCL Environment.
Precisely on the line which the EcoreEnvironmentFactory Instance is passed
to the OCL Interpreter:
I think its a configuration problem or somethink like that. Because the
exception is thrown bevor i do anything in my programm.
boolean valid;
OCLExpression<EClassifier> query = null;
try {
// create an OCL instance for Ecore
OCL<?, EClassifier, ?, ?, ?, ?, ?, ?, ?, Constraint, EClass, EObject>
ocl;
ocl = OCL.newInstance(EcoreEnvironmentFactory.INSTANCE); //EXCEPTION
// create an OCL helper object
OCLHelper<EClassifier, ?, ?, Constraint> helper =
ocl.createOCLHelper();
// set the OCL context classifier
helper.setContext(DmePackage.Literals.WRITER);
query = helper.createQuery("...");
valid = true;
} catch (ParserException e) {
// record failure to parse
valid = false;
System.err.println(e.getLocalizedMessage());
Exception in thread "main" java.lang.NoSuchMethodError:
org.eclipse.ocl.utilities.impl.UtilitiesPackageImpl.addEType Parameter(Lorg/eclipse/emf/ecore/EClassifier;Ljava/lang/Stri ng;)Lorg/eclipse/emf/ecore/ETypeParameter;
org.eclipse.ocl.utilities.impl.UtilitiesPackageImpl.initiali zePackageContents(UtilitiesPackageImpl.java:427)
org.eclipse.ocl.utilities.impl.UtilitiesPackageImpl.init(Uti litiesPackageImpl.java:173)
org.eclipse.ocl.utilities.UtilitiesPackage.<clinit>(UtilitiesPackage.java:70)
org.eclipse.ocl.types.impl.TypesPackageImpl.init(TypesPackag eImpl.java:205)
at org.eclipse.ocl.types.TypesPackage.<clinit>(TypesPackage.java:71)
org.eclipse.ocl.expressions.impl.ExpressionsPackageImpl.init (ExpressionsPackageImpl.java:416)
org.eclipse.ocl.expressions.ExpressionsPackage.<clinit>(ExpressionsPackage.java:72)
org.eclipse.ocl.ecore.EcoreEnvironment.<clinit>(EcoreEnvironment.java:82)
org.eclipse.ocl.ecore.EcoreEnvironmentFactory.createEnvironm ent(EcoreEnvironmentFactory.java:83)
at org.eclipse.ocl.OCL.<init>(OCL.java:73)
at org.eclipse.ocl.OCL.newInstance(OCL.java:131)Hallo
at oclValidator.OCLValidator.validate(OCLValidator.java:44)
at oclValidator.OCLValidator.main(OCLValidator.java:107)
best wishes and many thanks
LEE
Re: OCL Invariants on Ecore /EMF [message #46481 is a reply to message #46450] Wed, 12 December 2007 13:22 Go to previous messageGo to next message
Hi, Lee,
You are running with the wrong version of the EMF run-time. From the
exception, it looks like you are using version 2.2 or earlier, which
predates Ecore's support for generic types.
You need EMF 2.3 for OCL 1.1 and EMF 2.4 for OCL 1.2.
Christian
Lee wrote:
> Hi all,
> boolean valid;
> try {
> ocl;
> valid = true;
> valid = false;
> at
> at
> at
> at
> at
> at
> at
> at
> LEE
Re: OCL Invariants on Ecore /EMF [message #46510 is a reply to message #46481] Wed, 12 December 2007 14:53 Go to previous messageGo to next message
Damn,
you are right. I am using EMF 2.2.1 because i am obliged to use Eclipse
3.2.
Is there an other framework or Library, which i can use to validate my
(Ecore) model instances in EMF which OCL (Constraints/Invariants)?
Greets and thanks
lee
Re: OCL Invariants on Ecore /EMF [message #46562 is a reply to message #46510] Wed, 12 December 2007 17:13 Go to previous message
Hi, Lee,
Well, there is the 1.0.x releases of MDT OCL (a.k.a. EMFT OCL). These will
work with EMF 2.2, but that API is deprecated in the 1.1 and later
releases.
HTH,
Christian
Lee wrote:
> Damn,
> 3.2.
> Greets and thanks
> lee
Previous Topic:java.lang.ClassCircularityError: myPackage/ValidationDelegateClientSelector
Next Topic:[Announce] MDT OCL 1.2.0 I200712121716 is available
Current Time: Thu Jul 17 21:47:50 EDT 2025
Powered by FUDForum. Page generated in 0.25798 seconds
