Home » Language IDEs » PHP Development Tools (PDT) » Custom ide-tooltip-popup for functions
Custom ide-tooltip-popup for functions [message #46418] Sun, 26 August 2007 02:39 Go to next message
I don't know how to find info about this: when I type the name of a php
function the ide show a tooltip popup with infoemations about the function
and its parameters, something like
Description
This function do this and this...
Parameters
usefulparam int
Returns
int
Can I write documentation on my custom functions so that when they are
written the ide shows the infos about them?
How?
I hope to be clear :)
Re: Custom ide-tooltip-popup for functions [message #46477 is a reply to message #46418] Sun, 26 August 2007 07:36 Go to previous messageGo to next message
Originally posted by: reply-to-newsgroup.news.com
The documentation of a PHP function is taken by parsing the standard PHPDoc
block that exists right above the function.
You can read about the PHPDoc at: http://www.phpdoc.org/
Shalom Gibly
Zend
"Fabio" <znt.fabio@virgilio.it> wrote in message
news:far7kb$2rn$1@build.eclipse.org...
> Description
> Parameters
> usefulparam int
> Returns
> int
> How?
> Thanks
Re: Custom ide-tooltip-popup for functions [message #46502 is a reply to message #46477] Sun, 26 August 2007 08:08 Go to previous messageGo to next message
"Shalom Gibly" <reply-to-newsgroup@news.com> ha scritto nel messaggio
news:farojd$tk6$1@build.eclipse.org...
> PHPDoc block that exists right above the function.
Thank you, the syntax seems to be already supported by pdt.
The problem is that the tooltip is really small and it shows only a little
part of the description... :(
Re: Custom ide-tooltip-popup for functions [message #46529 is a reply to message #46502] Sun, 26 August 2007 09:08 Go to previous message
"Fabio" <znt.fabio@virgilio.it> ha scritto nel messaggio
news:farqfm$11b$1@build.eclipse.org...
Another question.
I try with something like
<?php
class my_class {
* Do a sum
* @param int $a
* @param int $b
* @return int
function sum($a,$b){ return $a+$b; }
When I type
$x = new my_class();
$x->
The tooltip says
/directory/file.php
Class:
my_class
Description:
Do a sum
Parameters:
int a
int b
It says the location and the class name that are not required, and then the
bottom is trunked so even the return type is listed :(
Previous Topic:Zend Debugger+suhosin=encrypted cookies=no session debug
Next Topic:How to find out debug_session_id?
Current Time: Mon Jul 14 01:58:19 EDT 2025
Powered by FUDForum. Page generated in 0.45987 seconds
