Home » Eclipse Projects » Plugin Development Environment (PDE) » How to test my plugin
How to test my plugin [message #46414] Wed, 11 February 2009 01:54 Go to next message
I am developing a plugin for Eclipse.
I try to write a simple testcase but it turned out it was not that simple.
This is the case.
public class ClearcaseProvider extends RepositoryProvider {
private final class RefreshStateOperation implements
IRecursiveOperation {
public IStatus visit(IResource resource, IProgressMonitor monitor)
StateCache cache =
StateCacheFactory.getInstance().get(resource);
Ok I thought since I cannot mock a singleton I can check if I really need
a singleton and make the coupling more lose. So I thought I could send an
instance of StateCacheFacotry into the constructor of ClearcaseProvider
class to make the two classes less tightly coupled. This is not possible
since that constructor will never be called from the Eclipse framework.
Any hints or pointers so I can test the plugin is very much appreciated.
//mikael
Re: How to test my plugin [message #46558 is a reply to message #46414] Wed, 11 February 2009 04:03 Go to previous messageGo to next message
Originally posted by: eclipse.kfdd.mine.nu
Just curious - have you looked at this for CC integration:
http://www.ibm.com/developerworks/rational/library/content/0 3July/2500/2834/ClearCase/clearcase_plugins.html
--Fredrik
Mikael Petterson wrote:
> simple. This is the case.
> public IStatus visit(IResource resource, IProgressMonitor monitor) {
> StateCache cache =
> need a singleton and make the coupling more lose. So I thought I could
> send an instance of StateCacheFacotry into the constructor of
> ClearcaseProvider class to make the two classes less tightly coupled.
> This is not possible since that constructor will never be called from
> //mikael
Re: How to test my plugin [message #46609 is a reply to message #46558] Wed, 11 February 2009 11:36 Go to previous message
Yes I have however that was not why I posted the question :-)
//mike
Re: How to test my plugin [message #591850 is a reply to message #46414] Wed, 11 February 2009 04:03 Go to previous message
--Fredrik
> StateCache cache =
> //mikael
Re: How to test my plugin [message #591867 is a reply to message #46558] Wed, 11 February 2009 11:36 Go to previous message
//mike
Previous Topic:Running the project builders when headless
Next Topic:OSGi running my own embedded Jetty, dependent plugins not starting?
Current Time: Sat Jul 12 13:55:36 EDT 2025
Powered by FUDForum. Page generated in 0.03869 seconds
