Home » Eclipse Projects » Nebula » Widget proposal: ImageCombo
Widget proposal: ImageCombo [message #46411] Sun, 13 January 2008 09:51 Go to next message
Originally posted by: tom.seidel.spiritlink.de
I was wondering if there is a need for a combo-widget with images for
nebula. If yes, I could contribute such a widget, see
http://www.richclient2.eu/2006_03_03/enhancing-the-combo-wid get-with-images/
Cheerz,
Tom
Re: Widget proposal: ImageCombo [message #46442 is a reply to message #46411] Sun, 13 January 2008 12:56 Go to previous messageGo to next message
I would love to see this widget getting a home at Nebula and I'd
volunteer to write a Viewer ontop of it (which is a fairly trivial task :-).
I have seen many requests on the newsgroups asking for such a widget
because other toolkits also provide this feature.
Tom
Tom Seidel schrieb:
> Cheerz,
> Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Widget proposal: ImageCombo [message #46528 is a reply to message #46411] Mon, 14 January 2008 11:21 Go to previous messageGo to next message
Tom Seidel wrote:
> Cheerz,
> Tom
This is great work. I have an ImageCombo of my own that is similar to
yours, but not as polished.
I also think any discussion about custom combos should include PCombo.
PCombo was part of SWTPlus before most of it was absorbed into Nebula.
PCombo was nice because you could put any control you wanted in the drop
down. It could be a calendar, color picker, whatever. It took care of
the combo idioms like focus handling, allocating, showing and hiding the
drop down. You in turn had to implement a strategy object that would
create the drop down control, and inform the combo when a selection was
made.
Matthew
Re: Widget proposal: ImageCombo [message #46741 is a reply to message #46442] Wed, 16 January 2008 18:39 Go to previous messageGo to next message
>I'd volunteer to write a Viewer ontop
Excellent :)
Tom
Re: Widget proposal: ImageCombo [message #46807 is a reply to message #46528] Thu, 17 January 2008 10:19 Go to previous messageGo to next message
I think there is definitely a need for a combo widget. I have the
PCombo code still somewhere if anyone wants to look at it or use it.
One tricky part with combos is the focus issues. Using standard widgets
inside the combo dropdown will cause the dropdown to get focus. I did
various things in PCombo to try to minimize them but their still there.
You can see titlebar flicker and under Mac its even worse.
If you write your own custom widget as the content in a dropdown and you
don't rely on any standard widgets... and your custom widget is designed
to never take focus, you can avoid these issues.
-Chris
Matthew Hall wrote:
> Tom Seidel wrote:
>> Cheerz,
>> Tom
> made.
> Matthew
Re: Widget proposal: ImageCombo [message #46837 is a reply to message #46807] Thu, 17 January 2008 10:27 Go to previous messageGo to next message
> PCombo code still somewhere if anyone wants to look at it or use it. One
Well CCombo suffers from the same problem IIRC.
Tom
Re: Widget proposal: ImageCombo [message #46866 is a reply to message #46807] Thu, 17 January 2008 10:55 Go to previous messageGo to next message
Chris Gross wrote:
> I have the
You posted it to the newsgroup here:
http://dev.eclipse.org/newslists/news.eclipse.technology.neb ula/msg00514.html
However when asked about license terms you said, "don't pretend you
wrote it," which is more like CC-Attribution rather than EPL. I think
for us to proceed in working on PCombo, you'll need to explicitly make
the contribution under EPL terms. Probably all that's necessary on your
part is to add the EPL license notice to each source file and post a
patch in bugzilla.
Matthew
Re: Widget proposal: ImageCombo [message #46895 is a reply to message #46837] Thu, 17 January 2008 11:17 Go to previous messageGo to next message
Yea it does and I think it leads to a host of issues. There are quite a
few bugzilla entries bout it.
regards,
-Chris
>> widgets inside the combo dropdown will cause the dropdown to get
>> focus. I did various things in PCombo to try to minimize them but
>> their still there. You can see titlebar flicker and under Mac its
>> even worse.
>> you don't rely on any standard widgets... and your custom widget is
>> designed to never take focus, you can avoid these issues.
> Tom
Re: Widget proposal: ImageCombo [message #46924 is a reply to message #46866] Thu, 17 January 2008 11:20 Go to previous messageGo to next message
Well I believe the DPYWI license is EPL compatible :P
I think I've essentially put it in the public domain. Anyone is free to
use it how they wish.
-Chris
Matthew Hall wrote:
> Chris Gross wrote:
>> I have the PCombo code still somewhere if anyone wants to look at it
>> or use it.
> patch in bugzilla.
> Matthew
Re: Widget proposal: ImageCombo [message #47014 is a reply to message #46924] Thu, 17 January 2008 18:47 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=205351
might be of intrest for this.
Tom
> -Chris
> Matthew Hall wrote:
>>> or use it.
>> your part is to add the EPL license notice to each source file and
>> post a patch in bugzilla.
>> Matthew
Re: Widget proposal: ImageCombo [message #587620 is a reply to message #46411] Sun, 13 January 2008 12:56 Go to previous message
Tom
Tom Seidel schrieb:
> Cheerz,
> Tom
Re: Widget proposal: ImageCombo [message #587643 is a reply to message #46411] Mon, 14 January 2008 11:21 Go to previous message
Tom Seidel wrote:
> Cheerz,
> Tom
made.
Matthew
Re: Widget proposal: ImageCombo [message #587731 is a reply to message #46442] Wed, 16 January 2008 18:39 Go to previous message
Excellent :)
Tom
Re: Widget proposal: ImageCombo [message #587757 is a reply to message #46528] Thu, 17 January 2008 10:19 Go to previous message
-Chris
Matthew Hall wrote:
> Tom Seidel wrote:
>> Cheerz,
>> Tom
> made.
> Matthew
Re: Widget proposal: ImageCombo [message #587766 is a reply to message #46807] Thu, 17 January 2008 10:27 Go to previous message
Tom
Re: Widget proposal: ImageCombo [message #587770 is a reply to message #46807] Thu, 17 January 2008 10:55 Go to previous message
Chris Gross wrote:
> I have the
patch in bugzilla.
Matthew
Re: Widget proposal: ImageCombo [message #587780 is a reply to message #46837] Thu, 17 January 2008 11:17 Go to previous message
regards,
-Chris
>> even worse.
> Tom
Re: Widget proposal: ImageCombo [message #587797 is a reply to message #46866] Thu, 17 January 2008 11:20 Go to previous message
-Chris
Matthew Hall wrote:
>> or use it.
> patch in bugzilla.
> Matthew
Re: Widget proposal: ImageCombo [message #587815 is a reply to message #46924] Thu, 17 January 2008 18:47 Go to previous message
Tom
> -Chris
> Matthew Hall wrote:
>>> or use it.
>> Matthew
Previous Topic:Grid row headers
Next Topic:Grid selection background color when not in focus
Current Time: Tue Jul 08 09:56:17 EDT 2025
Powered by FUDForum. Page generated in 0.12788 seconds
