Home » Newcomers » Newcomers » Eclipse IMPORT into my new project
Eclipse IMPORT into my new project [message #46407] Sun, 03 April 2005 18:57
Originally posted by: laurence.mediacult.com
I discovered that Eclipse does not import what you think it is:
if I select a sub-directory it will import the directory structure from the
root inside the new project;
example:
I select c below a/b/ to be imported,
Eclipse takes /a/b/c/d and put it in:
eclipse/workspace/NEWproject/a/b/c/d
After creating this new project under Perspective JAVA,
the project is not listed in Package Explorer (so I cannot open it)
but appears if I select Perspective JAVA BROWSING.
In Perspective JAVA, in Package Explorer an older Deleted project appears
after the colon "Package Explorer: GoViz". Spooky!
this is on Linux Fedora with eclipse Version: 3.0.1
Build id: 200409161125.
thanks
Laurie
Previous Topic:line numbers
Next Topic:CVS in Eclipse & Password requests
Current Time: Fri Jul 18 01:42:34 EDT 2025
Powered by FUDForum. Page generated in 0.22354 seconds
