Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT newbie question
SWT newbie question [message #458916] Tue, 26 July 2005 08:12 Go to next message
Originally posted by: alexander_buloichik.epam.com
Hi, All !
Sorry for stupid question, but I can't find answer on my question in the FAQ
and docs.
How can I create simple SWT application ?
I'm using Eclipse SDK 3.1(without any additional plugins) under Windows XP.
As far as I understand, I should add SWT libraries to my project(through
Properties/Java Build Path/Libraries/Add Library). But I can see only "JRE
System Library", "Plug-in Dependencies" and "User Library" lines.
When I click "Samples" on the "Welcome" screen, I downloaded SWT examples,
and can compile and run they. I see "org.eclipse.swt_3.1.0" and
"org.eclipse.swt.win32.win32.x86_3.1.0" under "Plug-in Dependencies" in the
"Library" tab.
WBR, Alex.
Re: SWT newbie question [message #458917 is a reply to message #458916] Tue, 26 July 2005 09:12 Go to previous messageGo to next message
Originally posted by: BertinK.tiscali.nl
Alexander Buloichik wrote:
> Hi, All !
> and docs.
> "Library" tab.
> WBR, Alex.
On the Java Build Path/Libraries tab I used "add external libraries" to
add the libraries. For example: org.eclipse.swt_3.1.0.jar
Re: SWT newbie question [message #458918 is a reply to message #458916] Tue, 26 July 2005 09:18 Go to previous messageGo to next message
Originally posted by: s-pflug.arcor.de
Alexander Buloichik schrieb:
> Hi, All !
> and docs.
> "Library" tab.
> WBR, Alex.
Select your project in Package Explorer, select "Properties" out of
context menu.
Select "Java Build Path | Libraries", with "Add External JARs" add the
following JARs:
"ECLIPSE_HOME/plugins/org.eclipse.osgi_3.1.0.jar"
"ECLIPSE_HOME/plugins/org.eclipse.ui.forms_3.1.0.jar"
"ECLIPSE_HOME/plugins/org.eclipse.core.runtime_3.1.0.jar"
" ECLIPSE_HOME/plugins/org.eclipse.swt.win32.win32.x86_3.1.0.j ar "
"ECLIPSE_HOME/plugins/org.eclipse.jface_3.1.0.jar"
"ECLIPSE_HOME/plugins/org.eclipse.jface.text_3.1.0.jar"
Re: SWT newbie question [message #458945 is a reply to message #458918] Tue, 26 July 2005 21:04 Go to previous messageGo to next message
http://www.eclipse.org/downloads/download.php?file=/eclipse/ downloads/drops/R-3.1-200506271435/eclipse-SDK-3.1-win32.zip
I download it from here. I can't find these jars
you mention above,when I was in search of the
plugins folder:
..jar"
..1.0.jar"
"ECLIPSE_HOME/plugins/org.eclipse.swt.win32.win3
2.x86_3.1.0.jar"
r"
..0.jar"
But I m sure that eclipse3.0 has them.So
confusing.
Thanks in Advance...
Augur, QunShun, ShangHai, China
________________________________________________
' If there is one, Knowledge is the "Fountain of
Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: SWT newbie question [message #458952 is a reply to message #458945] Wed, 27 July 2005 05:39 Go to previous messageGo to next message
> plugins folder:
> .jar"
> .1.0.jar"
> 2.x86_3.1.0.jar"
> r"
> .0.jar"
> confusing.
As your are using Eclipse 3.1 you wil find these JARs under your plugin
folder.
"ECLIPSE_HOME" == your eclipse installation directory
all JARs are named org.eclipse.*
Re: SWT newbie question [message #458979 is a reply to message #458952] Wed, 27 July 2005 23:43 Go to previous messageGo to next message
Only I can find their source code at the path of
C:\eclipse_3.1\plugins\org.eclipse.rcp.source_3.
1.0\src\org.eclipse.jface_3.1.0\src.zip.
Is it a download bug?
I downloaded it from a mirror -
http://www.eclipse.org/downloads/download.php?file=/eclipse/ downloads/drops/R-3.1-200506271435/eclipse-SDK-3.1-win32.zip &url=http://eclipse.cdpa.nsysu.edu.tw/downloads/drops/R- 3.1-200506271435/eclipse-SDK-3.1-win32.zip&mirror_id=40
Youth"'
Re: SWT newbie question [message #459295 is a reply to message #458979] Thu, 04 August 2005 23:27 Go to previous message
They are in C:\eclipse_3.1\plugins truely.
:),more convinient than before as for writing
ant file.
____________________________________________________________ ______________
Youth"'
Previous Topic:SwingWorker equivalent in SWT
Next Topic:May I make checkbox of table read_only?
Current Time: Sun Jul 06 08:08:19 EDT 2025
Powered by FUDForum. Page generated in 0.04306 seconds
