Home » Archived » OHF » ITI-14 - RetrieveDocument URI (Length Problem)
ITI-14 - RetrieveDocument URI (Length Problem) [message #46404] |
Thu, 21 August 2008 09:09  |
Hi Everybody!
Recently I have stumbled across an interesting problem, I am not quite
sure on how to solve. So I thought the best address would be the OHF
Newsgroup. ;)
Basically what I am trying to do is write some code that registers a
document set (ITI-14) with an IHE Registry. Currently I am testing with
the official NIST Registry (B).
Besides adding a document Hash and Size to every DocumentEntry, I want to
submit an URI to support the ITI-14, Retrieve Document.
Basically my URI looks something like:
http://SERVERNAME/axis2/services/DocumentRepositoryService/R etrieveDocument?param0=1.2.3.4.116030179011263034.1219323603 286.1¶m1=application/pdf
The problem is, that the official NIST Registry rejects my request. As
soon as I make the URI shorter (below 128 characters), everything works
correctly. Even special characters like ?, /, : and so on are no problem.
So I made some research and found this in the IHE Technical Framework:
The URI of the XDS Document to be used for retrieval by XDS.a Document
Consumer actors.
XDS.a does not constraint the format of this URI beyond RFC 2616. However,
the IHE Retrieve Information for Display Integration Profile defined
format may be used in cases where the Document repository is grouped with
a RID Information Source Actor (See ITI TF-1:Appendix E.5)
RID links can be used only if they yield the document in full fidelity.
There are two formats for coding this attribute. If the string
representing the URI is 128 characters or shorter, the short format may be
used:
<rim:Slot name="URI">
<rim:ValueList>
<rim:Value>http://www.ihe.net</rim:Value>
</rim:ValueList>
</rim:Slot>
If the string is more than 128 characters long, the long format shall be
used:
<rim:ValueList>
<rim:Value>1|http://www.ihe.net/ IHERetrieveDocument?</rim:Value>
<rim:Value>2|requestType=DOCUMENT&documentUID=1.2.3</rim:Value >
<rim:Value>3|&preferredContentType=application%2fpdf</rim:Value >
</rim:ValueList>
</rim:Slot>
Each Value is composed of an ordering prefix followed by a portion of the
actual URI string. The ordering prefix shall be sequential starting at the
value 1. When the long format is used, all Values shall have an ordering
prefix.
So basically String, that are longer than 128 characters have to be "split
into" the long format.
Taking a look at the message that I am sending to the NIST Registry
reveals that is is done exactly as shown in the example above.
But as soon as I have more than 128 characters and therefore use the long
format, I am rejected by the NIST Registry.
I hope someone has an answer or at least a helpful advice for me! ;)
Thanks in Advance for both your time and your knowledge!
Stefan
To make things concrete (and more complicated...): This is the message
that I am getting from the NIST registry upon sending an URI with more
than 128 characters:
Document registration failed. The registry responsemessage is:
<rs:RegistryResponse xmlns:rs="urn:oasis:names:tc:ebxml-regrep:xsd:rs:3.0"
status="urn:oasis:names:tc:ebxml-regrep:ResponseStatusType:Failure "><rs:RegistryErrorList><rs:RegistryError
codeContext="Registry rejected metadata submission:
com.sun.ebxml.registry.RegistryException: Batch entry 5 INSERT IGNORE INTO
Slot (sequenceId, name_, slotType, value, parent) VALUES( was aborted.
Call getNextException() to see the cause.
com.sun.ebxml.registry.persistence.rdb.SlotDAO.insert(SlotDA O.java:226)
com.sun.ebxml.registry.persistence.rdb.RegistryObjectDAO.ins ert(RegistryObjectDAO.java:243)
com.sun.ebxml.registry.persistence.rdb.ExtrinsicObjectDAO.in sert(ExtrinsicObjectDAO.java:155)
com.sun.ebxml.registry.persistence.rdb.SQLPersistenceManager Impl.insert(SQLPersistenceManagerImpl.java:394)
& ;#x9;at
com.sun.ebxml.registry.persistence.rdb.SQLPersistenceManager Impl.insert(SQLPersistenceManagerImpl.java:284)
& ;#x9;at
com.sun.ebxml.registry.persistence.PersistenceManagerImpl.in sert(PersistenceManagerImpl.java:52)
com.sun.ebxml.registry.lcm.LifeCycleManagerImpl.submitObject s(LifeCycleManagerImpl.java:126)
com.sun.ebxml.registry.interfaces.Request.process(Request.ja va:146)
gov.nist.ebxml.registry.MultiPartLCM.processLCMPostRequest(M ultiPartLCM.java:153)
com.sun.ebxml.registry.interfaces.rest.RestServlet.processPo stRequest(RestServlet.java:78)
com.sun.ebxml.registry.interfaces.rest.RestServlet.doPost(Re stServlet.java:103)
javax.servlet.http.HttpServlet.service(HttpServlet.java:763)
javax.servlet.http.HttpServlet.service(HttpServlet.java:856)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:284)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:204)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:257)
org.apache.catalina.core.StandardValveContext.invokeNext(Sta ndardValveContext.java:151)
org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:567)
org.apache.catalina.core.StandardContextValve.invokeInternal (StandardContextValve.java:245)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:199)
org.apache.catalina.authenticator.AuthenticatorBase.invoke(A uthenticatorBase.java:587)
org.apache.catalina.core.StandardValveContext.invokeNext(Sta ndardValveContext.java:149)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:184)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:164)
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogVa lve.java:578)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:156)
org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:972)
org.apache.coyote.tomcat5.CoyoteAdapter.service(CoyoteAdapte r.java:206)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:833)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:732)
& #x9;at
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:619)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:688)
java.lang.Thread.run(Thread.java:613)
& #xa;Nested exception
was:
Batch entry 5 INSERT IGNORE INTO Slot (sequenceId, name_, slotType,
value, parent) VALUES( was aborted. Call getNextException() to see the
cause.
org.postgresql.jdbc2.AbstractJdbc2Statement.executeBatch(Abs tractJdbc2Statement.java:107)
com.sun.ebxml.registry.persistence.rdb.SlotDAO.insert(SlotDA O.java:220)
& ;#x9;at
& ;#x9;at
& #x9;at
" errorCode="XDSRegistryError"
location="Exception thrown: java.lang.Exception
Registry rejected
entry 5 INSERT IGNORE INTO Slot (sequenceId, name_, slotType, value, parent)
VALUES( was aborted. Call getNextException() to see the cause.
& ;#x9;at
& ;#x9;at
& #x9;at
was:
cause.
& ;#x9;at
& ;#x9;at
& #x9;at
java. lang.Exception:
& ;#x9;at
& ;#x9;at
& #x9;at
was:
cause.
& ;#x9;at
& ;#x9;at
& #x9;at
& #x9;at
gov.nist.registry.ws.SubmitObjectsRequest.submit_to_backend_ registry(SubmitObjectsRequest.java:350)
gov.nist.registry.ws.SubmitObjectsRequest.SubmitObjectsReque stInternal(SubmitObjectsRequest.java:230)
	a t
gov.nist.registry.ws.SubmitObjectsRequest.submitObjectsReque st(SubmitObjectsRequest.java:67)
gov.nist.registry.ws.serviceclasses.RegistryB.SubmitObjectsR equest(RegistryB.java:32)
sun.reflect.GeneratedMethodAccessor61.invoke(Unknown Source)
java.lang.reflect.Method.invoke(Method.java:585)
&am p;#x9;at
gov.nist.registry.ws.receivers.AbstractXDSRawXMLINoutMessage Receiver.invokeBusinessLogic(AbstractXDSRawXMLINoutMessageRe ceiver.java:108)
org.apache.axis2.receivers.AbstractInOutMessageReceiver.invo keBusinessLogic(AbstractInOutMessageReceiver.java:40)&#x a;	at
org.apache.axis2.receivers.AbstractMessageReceiver.receive(A bstractMessageReceiver.java:96)
org.apache.axis2.engine.AxisEngine.receive(AxisEngine.java:1 45)
org.apache.axis2.transport.http.HTTPTransportUtils.processHT TPPostRequest(HTTPTransportUtils.java:275)
org.apache.axis2.transport.http.AxisServlet.doPost(AxisServl et.java:120)
javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:269)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:188)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:210)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:174)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:117)
org.apache.catalina.valves.FastCommonAccessLogValve.invoke(F astCommonAccessLogValve.java:482)
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogVa lve.java:542)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:108)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:151)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:870)
org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:665)&# xa;	at
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:528)
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:81)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:685)
" severity="Error"
/></rs:RegistryErrorList></rs:RegistryResponse>
Re: ITI-14 - RetrieveDocument URI (Length Problem) [message #46440 is a reply to message #46404] |
Thu, 21 August 2008 12:01   |
Hi Stefan -- you are correct. XDS's dependancy on the ebXML standard
encurrs these length limitations and the work around for URI is to split
(as in the example below). OHF already has logic (as you pointed out) to
do this splitting. Given the information below ... it seems that this is
a bug with NIST (or at least submitting the problem to them). They have
a bug reporting system you can submit this too --
http://ihe.univ-rennes1.fr/flyspray/index.php?tasks=all& project=1&highlight=10_2
Be sure to include the stack trace and the entire message. I'll
additionally pass this on to a contact in NIST and see what he has to
say. Of note - this week NIST is involved in a US NHIN project testing
event, so they may be swamped.
- Sarah
Stefan S. wrote:
> Hi Everybody!
> Newsgroup. ;)
> to submit an URI to support the ITI-14, Retrieve Document.
> Consumer actors.
> However, the IHE Retrieve Information for Display Integration Profile
> defined format may be used in cases where the Document repository is
> grouped with a RID Information Source Actor (See ITI TF-1:Appendix E.5)
> be used:
> <rim:ValueList>
> </rim:ValueList>
> </rim:Slot>
> used:
> <rim:ValueList>
> </rim:ValueList>
> </rim:Slot>
> the actual URI string. The ordering prefix shall be sequential starting
> at the value 1. When the long format is used, all Values shall have an
> ordering prefix.
> "split into" the long format.
> long format, I am rejected by the NIST Registry.
> Stefan
& ;#x9;at
& ;#x9;at
& #x9;at
> was:
> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
Registry rejected
> Batch entry 5 INSERT IGNORE INTO Slot (sequenceId, name_, slotType, value,
> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
> was:
> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
& ;#x9;at
& ;#x9;at
& #x9;at
> was:
> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
& #x9;at
	a t
&am p;#x9;at
" severity="Error"
Re: ITI-14 - RetrieveDocument URI (Length Problem) [message #46472 is a reply to message #46440] |
Thu, 21 August 2008 12:05   |
AH!!! ... Stefan!
I just reread your email and think I know what is going on. The URI
attribute is for the XDS.a profile. You'll need to post to the XDS.a
NIST registry endpoint, not the XDS.b one.
See if this fixes things. If not, then post the bug.
- Sarah
> - Sarah
> Stefan S. wrote:
>> Hi Everybody!
>> Newsgroup. ;)
>> with the official NIST Registry (B).
>> works correctly. Even special characters like ?, /, : and so on are no
>> problem.
>> Consumer actors.
>> may be used:
>> <rim:ValueList>
>> </rim:ValueList>
>> </rim:Slot>
>> be used:
>> <rim:ValueList>
>> </rim:ValueList>
>> </rim:Slot>
>> starting at the value 1. When the long format is used, all Values
>> shall have an ordering prefix.
>> Stefan
>> INTO Slot (sequenceId, name_, slotType, value, parent) VALUES( was
& ;#x9;at
& ;#x9;at
& #x9;at
>> was:
>> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
>> errorCode="XDSRegistryError" location="Exception thrown:
>> java.lang.Exception
& ;#x9;at
& ;#x9;at
& #x9;at
>> was:
>> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
& ;#x9;at
& ;#x9;at
& #x9;at
>> was:
>> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
& #x9;at
	a t
>> Source)
&am p;#x9;at
" severity="Error"
Re: ITI-14 - RetrieveDocument URI (Length Problem) [message #46504 is a reply to message #46472] |
Thu, 21 August 2008 14:08   |
Hi Sarah!
Thanks for your quick response. Don't worry, I am not sooo fast in posting
bugs at "official" places! ;)
I am aware of the fact, that I am posting to the XDS.b registry, but as
far as I am informed, the URI attribute is requried attribute for an XDS.b
registry and an optional attribute for XDS.b. Please correct me, if I am
wrong.
Greetings and Thanks!
Stefan
Sarah Knoop wrote:
> AH!!! ... Stefan!
> - Sarah
>> - Sarah
>> Stefan S. wrote:
>>> Hi Everybody!
>>> Newsgroup. ;)
>>> problem.
>>> Consumer actors.
>>> may be used:
>>> <rim:ValueList>
>>> </rim:ValueList>
>>> </rim:Slot>
>>> be used:
>>> <rim:ValueList>
>>> </rim:ValueList>
>>> </rim:Slot>
>>> Stefan
& ;#x9;at
& ;#x9;at
& #x9;at
>>> was:
>>> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
>>> java.lang.Exception
& ;#x9;at
& ;#x9;at
& #x9;at
>>> was:
>>> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
& ;#x9;at
& ;#x9;at
& #x9;at
>>> was:
>>> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
& #x9;at
	a t
>>> Source)
&am p;#x9;at
" severity="Error"
Re: ITI-14 - RetrieveDocument URI (Length Problem) [message #46538 is a reply to message #46504] |
Thu, 21 August 2008 15:02  |
Hi Stefan,
Correct URI is required for XDs.a, it can be included in XDS.b, but a
registry is NOT required to save the information. So if you want to be
able to query and get it back in the metadata -- safest thing is to use
XDS.a protocol and end point. XDS.b does require a repositoryUniqueId --
so be sure you submit this along with your metadata. The submission will
be rejected otherwise.
As far as this particular error -- it does almost seem to me that NIST
is not parsing the slot with multiple values. But before I raise an
alarm -- I want to be sure that everything else is correct.
- Sarah
Stefan S. wrote:
> Hi Sarah!
> posting bugs at "official" places! ;)
> XDS.b registry and an optional attribute for XDS.b. Please correct me,
> if I am wrong.
> Stefan
> Sarah Knoop wrote:
>> AH!!! ... Stefan!
>> - Sarah
>>> split (as in the example below). OHF already has logic (as you
>>> pointed out) to do this splitting. Given the information below ... it
>>> seems that this is a bug with NIST (or at least submitting the
>>> problem to them). They have a bug reporting system you can submit
>>> this too --
>>> testing event, so they may be swamped.
>>> - Sarah
>>> Stefan S. wrote:
>>>> Hi Everybody!
>>>> quite sure on how to solve. So I thought the best address would be
>>>> the OHF Newsgroup. ;)
>>>> want to submit an URI to support the ITI-14, Retrieve Document.
>>>> As soon as I make the URI shorter (below 128 characters), everything
>>>> no problem.
>>>> Document Consumer actors.
>>>> Profile defined format may be used in cases where the Document
>>>> repository is grouped with a RID Information Source Actor (See ITI
>>>> TF-1:Appendix E.5)
>>>> may be used:
>>>> <rim:ValueList>
>>>> </rim:ValueList>
>>>> </rim:Slot>
>>>> shall be used:
>>>> <rim:ValueList>
>>>> </rim:ValueList>
>>>> </rim:Slot>
>>>> of the actual URI string. The ordering prefix shall be sequential
>>>> Stefan
>>>> message that I am getting from the NIST registry upon sending an URI
>>>> with more than 128 characters:
& ;#x9;at
& ;#x9;at
& #x9;at
>>>> was:
>>>> slotType, value, parent) VALUES( was aborted. Call
& ;#x9;at
& ;#x9;at
& #x9;at
>>>> java.lang.Exception
& ;#x9;at
& ;#x9;at
& #x9;at
>>>> was:
& ;#x9;at
& ;#x9;at
& #x9;at
& ;#x9;at
& ;#x9;at
& #x9;at
>>>> was:
& ;#x9;at
& ;#x9;at
& #x9;at
& #x9;at
	a t
>>>> Source)
&am p;#x9;at
" severity="Error"
Re: ITI-14 - RetrieveDocument URI (Length Problem) [message #587046 is a reply to message #46404] |
- Sarah
Stefan S. wrote:
> Hi Everybody!
> Newsgroup. ;)
> Consumer actors.
> be used:
> <rim:ValueList>
> </rim:ValueList>
> </rim:Slot>
> used:
> <rim:ValueList>
> </rim:ValueList>
> </rim:Slot>
> ordering prefix.
> Stefan
& ;#x9;at
& ;#x9;at
& #x9;at
> was:
> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
Registry rejected
> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
> was:
> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
& ;#x9;at
& ;#x9;at
& #x9;at
> was:
> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
& #x9;at
	a t
&am p;#x9;at
" severity="Error"
Re: ITI-14 - RetrieveDocument URI (Length Problem) [message #587061 is a reply to message #46440] |
AH!!! ... Stefan!
- Sarah
> - Sarah
> Stefan S. wrote:
>> Hi Everybody!
>> Newsgroup. ;)
>> problem.
>> Consumer actors.
>> may be used:
>> <rim:ValueList>
>> </rim:ValueList>
>> </rim:Slot>
>> be used:
>> <rim:ValueList>
>> </rim:ValueList>
>> </rim:Slot>
>> Stefan
& ;#x9;at
& ;#x9;at
& #x9;at
>> was:
>> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
>> java.lang.Exception
& ;#x9;at
& ;#x9;at
& #x9;at
>> was:
>> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
& ;#x9;at
& ;#x9;at
& #x9;at
>> was:
>> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
& #x9;at
	a t
>> Source)
&am p;#x9;at
" severity="Error"
Re: ITI-14 - RetrieveDocument URI (Length Problem) [message #587072 is a reply to message #46472] |
Hi Sarah!
wrong.
Stefan
Sarah Knoop wrote:
> AH!!! ... Stefan!
> - Sarah
>> - Sarah
>> Stefan S. wrote:
>>> Hi Everybody!
>>> Newsgroup. ;)
>>> problem.
>>> Consumer actors.
>>> may be used:
>>> <rim:ValueList>
>>> </rim:ValueList>
>>> </rim:Slot>
>>> be used:
>>> <rim:ValueList>
>>> </rim:ValueList>
>>> </rim:Slot>
>>> Stefan
& ;#x9;at
& ;#x9;at
& #x9;at
>>> was:
>>> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
>>> java.lang.Exception
& ;#x9;at
& ;#x9;at
& #x9;at
>>> was:
>>> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
& ;#x9;at
& ;#x9;at
& #x9;at
>>> was:
>>> cause.
& ;#x9;at
& ;#x9;at
& #x9;at
& #x9;at
	a t
>>> Source)
&am p;#x9;at
" severity="Error"
Re: ITI-14 - RetrieveDocument URI (Length Problem) [message #587084 is a reply to message #46504] |
Hi Stefan,
- Sarah
Stefan S. wrote:
> Hi Sarah!
> if I am wrong.
> Stefan
> Sarah Knoop wrote:
>> AH!!! ... Stefan!
>> - Sarah
>>> this too --
>>> - Sarah
>>> Stefan S. wrote:
>>>> Hi Everybody!
>>>> no problem.
>>>> TF-1:Appendix E.5)
>>>> may be used:
>>>> <rim:ValueList>
>>>> </rim:ValueList>
>>>> </rim:Slot>
>>>> shall be used:
>>>> <rim:ValueList>
>>>> </rim:ValueList>
>>>> </rim:Slot>
>>>> Stefan
& ;#x9;at
& ;#x9;at
& #x9;at
>>>> was:
& ;#x9;at
& ;#x9;at
& #x9;at
>>>> java.lang.Exception
& ;#x9;at
& ;#x9;at
& #x9;at
>>>> was:
& ;#x9;at
& ;#x9;at
& #x9;at
& ;#x9;at
& ;#x9;at
& #x9;at
>>>> was:
& ;#x9;at
& ;#x9;at
& #x9;at
& #x9;at
	a t
>>>> Source)
&am p;#x9;at
" severity="Error"
Current Time: Thu Jul 17 21:47:31 EDT 2025
Powered by FUDForum. Page generated in 0.61343 seconds
