Home » Eclipse Projects » Mylyn » Wrong context retrieve after eclipse startup
Wrong context retrieve after eclipse startup [message #46400] Tue, 01 April 2008 11:08 Go to next message
Originally posted by: b_apolci.libero.it
The first time I activate a task after eclipse startup it load a wrong
context.
Here is an example:
Task1 has only one file in the context (file1) that was open last time I
deactivated the task.
I start eclipse and I have file2 and file3 already open and no task
activated.
I activate Task1. I expected that file2 and file3 were closed and file1
is open. Insteand the open editors don't change: file2 and 3 remain open
and fil1 don't open.
Now if I close Task1 all editors close as expected.
It only happens on first task activation after eclipse startup.
Is this a known problem?
Andrea
Re: Wrong context retrieve after eclipse startup [message #46490 is a reply to message #46400] Thu, 03 April 2008 09:24 Go to previous message
> context.
I've found an open bug for this problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=211168
Thanks the same.
Andrea
Re: Wrong context retrieve after eclipse startup [message #588825 is a reply to message #46400] Thu, 03 April 2008 09:24 Go to previous message
> context.
Thanks the same.
Andrea
Previous Topic:[2.3.1] [Task List] Clear button doesn't work anymore
Next Topic:Mylyn - "open resource" to context
Current Time: Sat Jul 12 11:06:09 EDT 2025
Powered by FUDForum. Page generated in 0.03658 seconds
