Home » Archived » M2M (model-to-model transformation) » [ATL] Sequence as a source pattern ?
[ATL] Sequence as a source pattern ? [message #46391] Thu, 14 June 2007 05:40 Go to next message
Originally posted by: milan.milanovic.org
what do you think, is it possible to write rule rule like this:
lazy rule Operation {
from i : Sequence (R2ML!ReactionRule)
to part : WSDL!Operation (
I think that it is working.
Best regards, Milan Milanovic
Re: [ATL] Sequence as a source pattern ? [message #47319 is a reply to message #46391] Mon, 18 June 2007 06:59 Go to previous message
It may be working, but it has neither been defined nor been tested yet.
In this case, it may be safer to use a called rule for the time being.
Frédéric Jouault
Previous Topic:in-place transformation
Next Topic:[ATL] UseCase 2 HighLevel rules
Current Time: Tue Jul 15 06:46:11 EDT 2025
Powered by FUDForum. Page generated in 0.02351 seconds
