Home » Archived » BIRT » [ANN] Use POJOs as DataSource Example
[ANN] Use POJOs as DataSource Example [message #46386] Wed, 15 June 2005 10:16 Go to next message
Hi all
i have post an article[1] that demostrate the usage of POJOs as datasource
for BIRT reports
Next days i'will add the source code for download too.
I hope that this will be helpfull someone!
ps.
A note for BIRT's developers.
BIRT's viewer webapp that used to render (preview) the report in designer
can not find custom classes that provide the data. To do that happend i have
to create a [classes] folder in viewer's plug-in (/birt/web-inf) and put
them there.
This is not a problem in production mode but it's painfull in design mode
when you have to make changes and preview your report. Is it any workaround
about this issue. (a reference from report's project to onother open project
in eclipse's worksace, maybe)
[1] http://tools.osmosis.gr/blog/archives/2005/06/birt_and_objec t.html
Best Regards
Stavros
Re: [ANN] Use POJOs as DataSource Example [message #46447 is a reply to message #46386] Wed, 15 June 2005 11:23 Go to previous messageGo to next message
Originally posted by: m.n.com
Thanks for posting this. What I am trying to do is figure out how to
report off a previously selected list of POJOs.
Re: [ANN] Use POJOs as DataSource Example [message #47020 is a reply to message #46386] Thu, 16 June 2005 04:03 Go to previous messageGo to next message
<snip>
> Hi all
> for BIRT reports
</snip>
I have just add the source code in this article (eclipse project).
best regards
-stavros
Re: [ANN] Use POJOs as DataSource Example [message #47513 is a reply to message #46386] Fri, 17 June 2005 10:48 Go to previous messageGo to next message
Hi Stavros
Thanks for the hints! It works well except that In my case ( im
programming a design directly in java) the different row values dosent
show. For some reason only value for [0] are shown . The number of rows
is correct so the counting works but in fetch.
row["a"] = lRows[count].getA()
seems to be executed once or in any case it returns he same value all
the time.
Any hints on what it could be ?
thanks
/anders
Stavros Kounis wrote:
> Hi all
> for BIRT reports
> ps.
> them there.
> Best Regards
> Stavros
Re: [ANN] Use POJOs as DataSource Example [message #47542 is a reply to message #46386] Fri, 17 June 2005 10:48 Go to previous messageGo to next message
Hi Stavros
the time.
thanks
/anders
> Hi all
> for BIRT reports
> ps.
> them there.
> Best Regards
> Stavros
Re: [ANN] Use POJOs as DataSource Example [message #47723 is a reply to message #47542] Fri, 17 June 2005 12:29 Go to previous messageGo to next message
<user@domain.invalid> wrote in message news:d8uns9$vvo$1@news.eclipse.org...
> Hi Stavros
> show. For some reason only value for [0] are shown . The number of rows is
> seems to be executed once or in any case it returns he same value all the
> time.
hi anders
stupid maybe but did you increase "count" value inside the fetch method?
for example
<snip>
if (count < {your iterator limits} ){
count ++; row["a"] = lRows[count].getA() return true;
return false;stavros</snip>
> thanks
> /anders
>> Hi all
>> datasource for BIRT reports
>> ps.
>> have to create a [classes] folder in viewer's plug-in (/birt/web-inf) and
>> put them there.
>> workaround about this issue. (a reference from report's project to
>> onother open project in eclipse's worksace, maybe)
>> Best Regards
>> Stavros
Re: [ANN] Use POJOs as DataSource Example [message #47784 is a reply to message #47723] Fri, 17 June 2005 16:43 Go to previous message
Hi Stavros,
I got it now, I made the dataSet binding onthe individual dataitems and
not on the list to which they belong. So changing to a binding on table,
fixing resultset and adding columnhints etc it works nicely.
cheers
/anders
>>Hi Stavros
>>time.
> hi anders
> for example
> <snip>
>>thanks
>>/anders
>>>Hi all
>>>ps.
>>>put them there.
>>>Best Regards
>>>Stavros
Previous Topic:A few easy questions about your experience with BIRT
Next Topic:tree control
Current Time: Mon Jul 21 21:18:03 EDT 2025
Powered by FUDForum. Page generated in 0.28013 seconds
