Home » Eclipse Projects » Plugin Development Environment (PDE) » OSGi running my own embedded Jetty, dependent plugins not starting?
OSGi running my own embedded Jetty, dependent plugins not starting? [message #46349] Tue, 10 February 2009 13:23 Go to next message
Originally posted by: david.roamware.co.uk
I cannot use the version of Jetty that is available in Eclipse. So I
embedded the latest Jetty version. This all runs fine when running under
Eclipse debug. I put together a OSGi configuration that seems to work,
partially, my BundleActivator class starts Jetty, it is listening on
port 8081 as specified.
Here is the stack when started via Debug OSGi Framework in Eclispe
org.eclipse.equinox.launcher.Main at localhost:4723
Thread [main] (Running)
Thread [OSGi Console] (Running)
Daemon Thread [State Data Manager] (Running)
Daemon Thread [Framework Event Dispatcher] (Running)
Daemon Thread [Start Level Event Dispatcher] (Running)
Thread [Worker-0] (Running)
Daemon Thread [Timer-0] (Running)
Thread [btpool0-0 - Acceptor0 SelectChannelConnector@0.0.0.0:8081]
(Running)
Thread [btpool0-1 - Acceptor0 SslSocketConnector@0.0.0.0:8443] (Running)
The trouble is that it never responds to a URL
http://localhost:8081/secm/index.html
That otherwise works while under debug.
Here is the stack under debug
com.stpware.secm.jetty.JettyLauncher at localhost:4785
(Running)
Daemon Thread [Timer-1] (Running)
Daemon Thread [Store org.hibernate.cache.UpdateTimestampsCache Spool
Thread] (Running)
Daemon Thread [Store org.hibernate.cache.UpdateTimestampsCache Expiry
Thread] (Running)
Daemon Thread [Store org.hibernate.cache.StandardQueryCache Spool
Thread] (Running)
Daemon Thread [Store org.hibernate.cache.StandardQueryCache Expiry
Thread] (Running)
Daemon Thread [H2 File Lock Watchdog
D:\workspace\SecmSecurity\db\secmsecurity.lock.db] (Running)
Daemon Thread [H2 Log Writer SECMSECURITY] (Running)
Thread] (Running)
Thread] (Running)
Thread] (Running)
Thread] (Running)
Thread [pool-1-thread-1] (Running)
Thread [pool-2-thread-1] (Running)
It looks like the 2 of my plugins it is dependent on are not starting.
One has all the Hibernate jars etc, and the other provides a service.
Both have their MANIFEST.MF setup to export the required interfaces and
classes.
Here are the 3 MANIFEST.MF
This one
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: %pluginName
Bundle-SymbolicName: GenSec2; singleton:=true
Bundle-Version: 1.0.0
Bundle-ClassPath:
..,.\web\WEB-INF\lib\jetty-6.1.9.jar,.\web\WEB-INF\lib\c3p0- 0.9.1.2.jar,.\web\WEB-INF\lib\commons-beanutils-1.8.0.jar,.\ web\WEB-INF\lib\commons-lang-2.4.jar,.\web\WEB-INF\lib\ehcac he-1.6.0-beta2.jar,.\web\WEB-INF\lib\jetty-util-6.1.9.jar,.\ web\WEB-INF\lib\servlet-api-2.5.jar
Bundle-Activator: com.stpware.secm.SecmActivator
Bundle-Vendor: %providerName
Bundle-Localization: plugin
Bundle-RequiredExecutionEnvironment: JavaSE-1.6,
OSGi/Minimum-1.1
Export-Package: com.stpenable.gensec,
com.stpenable.gensec.impl,
com.stpenable.gensec.util
Require-Bundle: org.eclipse.core.runtime;bundle-version="3.4.0",
org.eclipse.emf.ecore;bundle-version="2.4.1";visibility:=reexport,
org.eclipse.emf.ecore.xmi;bundle-version="2.4.1";visibility:=reexport,
org.eclipse.emf.teneo.hibernate;bundle-version="1.0.1";visibility:=reexport,
hibernate3;bundle-version="1.0.0",
SecmSec;bundle-version="1.0.0"
Eclipse-LazyStart: true
Is dependent on this one
Bundle-SymbolicName: SecmSec;singleton:=true
Bundle-ClassPath: .
Bundle-RequiredExecutionEnvironment: J2SE-1.5
Export-Package: com.stpware.secmsecurity,
com.stpware.secmsecurity.impl,
com.stpware.secmsecurity.manager,
com.stpware.secmsecurity.util
Require-Bundle: org.eclipse.core.runtime,
org.eclipse.emf.ecore;visibility:=reexport,
org.eclipse.emf.ecore.xmi;visibility:=reexport,
Bundle-ActivationPolicy: lazy
Both are dependent on this one
Bundle-Name: Hibernate3 Plug-in
Bundle-SymbolicName: hibernate3;singleton:=true
Bundle-ClassPath: .,
antlr-2.7.6.jar,
commons-collections-3.1.jar,
commons-logging-1.0.4.jar,
db2jcc.jar,
dom4j-1.6.1.jar,
dwr.jar,
ehcache-1.2.3.jar,
h2-1.1.107.jar,
hibernate3.jar,
javassist-3.4.GA.jar,
jaxen-1.1-beta-7.jar,
jdbc2_0-stdext.jar,
jta-1.1.jar,
log4j-1.2.15.jar,
mysql-connector-java-3.1.10-bin.jar,
slf4j-api-1.5.2.jar,
slf4j-log4j12-1.5.2.jar,
xml-apis.jar
Export-Package: COM.ibm.db2.app,
COM.ibm.db2os390.sqlj.custom,
COM.ibm.db2os390.sqlj.jdbc,
antlr,
antlr.ASdebug,
antlr.actions.cpp,
antlr.actions.csharp,
antlr.actions.java,
antlr.actions.python,
antlr.build,
antlr.collections,
antlr.collections.impl,
antlr.debug,
antlr.debug.misc,
antlr.preprocessor,
com.ibm.db2.jcc,
com.ibm.db2.jcc.a,
com.ibm.db2.jcc.b,
com.ibm.db2.jcc.resources,
com.ibm.db2.jcc.sqlj,
com.ibm.db2.jcc.t2,
com.ibm.db2.jcc.t2zos,
com.ibm.db2.jcc.t4,
com.ibm.db2.jcc.uw,
com.ibm.db2.jcc.uw.a,
com.ibm.db2.jcc.uw.classloader,
com.mysql.jdbc,
com.mysql.jdbc.integration.c3p0,
com.mysql.jdbc.integration.jboss,
com.mysql.jdbc.jdbc2.optional,
com.mysql.jdbc.log,
com.mysql.jdbc.profiler,
com.mysql.jdbc.util,
javassist,
javassist.bytecode,
javassist.bytecode.annotation,
javassist.compiler,
javassist.compiler.ast,
javassist.convert,
javassist.expr,
javassist.runtime,
javassist.scopedpool,
javassist.tools,
javassist.tools.reflect,
javassist.tools.rmi,
javassist.tools.web,
javassist.util,
javassist.util.proxy,
javax.sql,
javax.transaction,
javax.transaction.xa,
javax.xml.parsers,
javax.xml.transform,
javax.xml.transform.dom,
javax.xml.transform.sax,
javax.xml.transform.stream,
jsx3,
jsx3.app,
jsx3.chart,
jsx3.gui,
jsx3.gui.matrix,
jsx3.html,
jsx3.lang,
jsx3.net,
jsx3.util,
jsx3.vector,
jsx3.xml,
net.sf.ehcache,
net.sf.ehcache.bootstrap,
net.sf.ehcache.config,
net.sf.ehcache.constructs.asynchronous,
net.sf.ehcache.constructs.blocking,
net.sf.ehcache.constructs.concurrent,
net.sf.ehcache.constructs.web,
net.sf.ehcache.constructs.web.filter,
net.sf.ehcache.distribution,
net.sf.ehcache.event,
net.sf.ehcache.hibernate,
net.sf.ehcache.store,
net.sf.ehcache.util,
org.apache.commons.collections,
org.apache.commons.collections.bag,
org.apache.commons.collections.bidimap,
org.apache.commons.collections.buffer,
org.apache.commons.collections.collection,
org.apache.commons.collections.comparators,
org.apache.commons.collections.functors,
org.apache.commons.collections.iterators,
org.apache.commons.collections.keyvalue,
org.apache.commons.collections.list,
org.apache.commons.collections.map,
org.apache.commons.collections.set,
org.apache.commons.logging,
org.apache.commons.logging.impl,
org.apache.log4j,
org.apache.log4j.chainsaw,
org.apache.log4j.config,
org.apache.log4j.helpers,
org.apache.log4j.jdbc,
org.apache.log4j.jmx,
org.apache.log4j.lf5,
org.apache.log4j.lf5.util,
org.apache.log4j.lf5.viewer,
org.apache.log4j.lf5.viewer.categoryexplorer,
org.apache.log4j.lf5.viewer.configure,
org.apache.log4j.net,
org.apache.log4j.nt,
org.apache.log4j.or,
org.apache.log4j.or.jms,
org.apache.log4j.or.sax,
org.apache.log4j.spi,
org.apache.log4j.varia,
org.apache.log4j.xml,
org.apache.xmlcommons,
org.directwebremoting,
org.directwebremoting.annotations,
org.directwebremoting.bayeux,
org.directwebremoting.beehive,
org.directwebremoting.contrib,
org.directwebremoting.convert,
org.directwebremoting.create,
org.directwebremoting.dwrp,
org.directwebremoting.event,
org.directwebremoting.export,
org.directwebremoting.extend,
org.directwebremoting.faces,
org.directwebremoting.filter,
org.directwebremoting.fluent,
org.directwebremoting.guice,
org.directwebremoting.guice.spring,
org.directwebremoting.hibernate,
org.directwebremoting.impl,
org.directwebremoting.io,
org.directwebremoting.jms,
org.directwebremoting.json,
org.directwebremoting.proxy,
org.directwebremoting.proxy.browser,
org.directwebremoting.proxy.dwr,
org.directwebremoting.proxy.io,
org.directwebremoting.proxy.jsx3,
org.directwebremoting.proxy.jsx3.app,
org.directwebremoting.proxy.jsx3.chart,
org.directwebremoting.proxy.jsx3.gui,
org.directwebremoting.proxy.jsx3.html,
org.directwebremoting.proxy.jsx3.lang,
org.directwebremoting.proxy.jsx3.net,
org.directwebremoting.proxy.jsx3.util,
org.directwebremoting.proxy.jsx3.vector,
org.directwebremoting.proxy.jsx3.xml,
org.directwebremoting.proxy.scriptaculous,
org.directwebremoting.servlet,
org.directwebremoting.spring,
org.directwebremoting.struts,
org.directwebremoting.util,
org.directwebremoting.webwork,
org.dom4j,
org.dom4j.bean,
org.dom4j.datatype,
org.dom4j.dom,
org.dom4j.dtd,
org.dom4j.io,
org.dom4j.jaxb,
org.dom4j.rule,
org.dom4j.rule.pattern,
org.dom4j.swing,
org.dom4j.tree,
org.dom4j.util,
org.dom4j.xpath,
org.dom4j.xpp,
org.gjt.mm.mysql,
org.hibernate,
org.hibernate.action,
org.hibernate.bytecode,
org.hibernate.bytecode.cglib,
org.hibernate.bytecode.javassist,
org.hibernate.bytecode.util,
org.hibernate.cache,
org.hibernate.cache.access,
org.hibernate.cache.entry,
org.hibernate.cache.impl,
org.hibernate.cache.impl.bridge,
org.hibernate.cache.jbc2,
org.hibernate.cache.jbc2.access,
org.hibernate.cache.jbc2.builder,
org.hibernate.cache.jbc2.collection,
org.hibernate.cache.jbc2.entity,
org.hibernate.cache.jbc2.query,
org.hibernate.cache.jbc2.timestamp,
org.hibernate.cache.jbc2.util,
org.hibernate.cfg,
org.hibernate.classic,
org.hibernate.collection,
org.hibernate.connection,
org.hibernate.context,
org.hibernate.criterion,
org.hibernate.dialect,
org.hibernate.dialect.function,
org.hibernate.dialect.lock,
org.hibernate.engine,
org.hibernate.engine.loading,
org.hibernate.engine.query,
org.hibernate.engine.query.sql,
org.hibernate.engine.transaction,
org.hibernate.event,
org.hibernate.event.def,
org.hibernate.exception,
org.hibernate.hql,
org.hibernate.hql.antlr,
org.hibernate.hql.ast,
org.hibernate.hql.ast.exec,
org.hibernate.hql.ast.tree,
org.hibernate.hql.ast.util,
org.hibernate.hql.classic,
org.hibernate.id,
org.hibernate.id.enhanced,
org.hibernate.id.insert,
org.hibernate.impl,
org.hibernate.intercept,
org.hibernate.intercept.cglib,
org.hibernate.intercept.javassist,
org.hibernate.jdbc,
org.hibernate.jdbc.util,
org.hibernate.jmx,
org.hibernate.loader,
org.hibernate.loader.collection,
org.hibernate.loader.criteria,
org.hibernate.loader.custom,
org.hibernate.loader.custom.sql,
org.hibernate.loader.entity,
org.hibernate.loader.hql,
org.hibernate.lob,
org.hibernate.mapping,
org.hibernate.metadata,
org.hibernate.param,
org.hibernate.persister,
org.hibernate.persister.collection,
org.hibernate.persister.entity,
org.hibernate.pretty,
org.hibernate.property,
org.hibernate.proxy,
org.hibernate.proxy.dom4j,
org.hibernate.proxy.map,
org.hibernate.proxy.pojo,
org.hibernate.proxy.pojo.cglib,
org.hibernate.proxy.pojo.javassist,
org.hibernate.repackage.cglib.asm,
org.hibernate.repackage.cglib.asm.attrs,
org.hibernate.repackage.cglib.beans,
org.hibernate.repackage.cglib.core,
org.hibernate.repackage.cglib.proxy,
org.hibernate.repackage.cglib.reflect,
org.hibernate.repackage.cglib.transform,
org.hibernate.repackage.cglib.transform.hook,
org.hibernate.repackage.cglib.transform.impl,
org.hibernate.repackage.cglib.util,
org.hibernate.secure,
org.hibernate.sql,
org.hibernate.stat,
org.hibernate.tool.hbm2ddl,
org.hibernate.tool.instrument,
org.hibernate.tool.instrument.cglib,
org.hibernate.tool.instrument.javassist,
org.hibernate.transaction,
org.hibernate.transform,
org.hibernate.tuple,
org.hibernate.tuple.component,
org.hibernate.tuple.entity,
org.hibernate.type,
org.hibernate.usertype,
org.hibernate.util,
org.jaxen,
org.jaxen.dom,
org.jaxen.dom4j,
org.jaxen.expr,
org.jaxen.expr.iter,
org.jaxen.function,
org.jaxen.function.ext,
org.jaxen.function.xslt,
org.jaxen.javabean,
org.jaxen.jdom,
org.jaxen.pattern,
org.jaxen.saxpath,
org.jaxen.saxpath.base,
org.jaxen.saxpath.helpers,
org.jaxen.util,
org.jaxen.xom,
org.slf4j,
org.slf4j.helpers,
org.slf4j.impl,
org.slf4j.spi,
org.w3c.dom,
org.w3c.dom.css,
org.w3c.dom.events,
org.w3c.dom.html,
org.w3c.dom.ranges,
org.w3c.dom.stylesheets,
org.w3c.dom.traversal,
org.w3c.dom.views,
org.xml.sax,
org.xml.sax.ext,
org.xml.sax.helpers,
sqlj.runtime,
sqlj.runtime.error,
sqlj.runtime.profile,
sqlj.runtime.profile.ref,
sqlj.runtime.profile.util,
sqlj.runtime.ref,
sqlj.runtime.util,
uk.ltd.getahead.dwr,
uk.ltd.getahead.dwr.compat
I am not quite sure where to start looking next. Any pointers?
Thx.
David
Re: OSGi running my own embedded Jetty, dependent plugins not starting? [message #46633 is a reply to message #46349] Wed, 11 February 2009 13:10 Go to previous message
I have RTFM but must be missing something, any help? I am at the point
of ditching this OSGi approach, because I have to deploy...
One thing I do not understand, if Eclipse has enough information to
record dependencies and run successfully, then how come generating the
MANIFEST.MF cannot incorporate this information from plugins.xml to
create a working set of MANIFEST.MF for the same dependent bundles?
Thx.
David
David Wynter wrote:
> (Running)
> (Running)
> (Running)
> Thread] (Running)
> Expiry Thread] (Running)
> Thread] (Running)
> Thread] (Running)
> Thread] (Running)
> Thread] (Running)
> Thread] (Running)
> (Running)
> classes.
> This one
> Bundle-ClassPath:
> .,.\web\WEB-INF\lib\jetty-6.1.9.jar,.\web\WEB-INF\lib\c3p0-0 .9.1.2.jar,.\web\WEB-INF\lib\commons-beanutils-1.8.0.jar,.\w eb\WEB-INF\lib\commons-lang-2.4.jar,.\web\WEB-INF\lib\ehcach e-1.6.0-beta2.jar,.\web\WEB-INF\lib\jetty-util-6.1.9.jar,.\w eb\WEB-INF\lib\servlet-api-2.5.jar
> OSGi/Minimum-1.1
> Bundle-ClassPath: .
> antlr-2.7.6.jar,
> db2jcc.jar,
> dom4j-1.6.1.jar,
> dwr.jar,
> ehcache-1.2.3.jar,
> h2-1.1.107.jar,
> hibernate3.jar,
> jdbc2_0-stdext.jar,
> jta-1.1.jar,
> log4j-1.2.15.jar,
> xml-apis.jar
> antlr,
> antlr.ASdebug,
> antlr.actions.cpp,
> antlr.actions.java,
> antlr.build,
> antlr.collections,
> antlr.debug,
> antlr.debug.misc,
> antlr.preprocessor,
> com.ibm.db2.jcc,
> com.ibm.db2.jcc.a,
> com.ibm.db2.jcc.b,
> com.ibm.db2.jcc.t2,
> com.ibm.db2.jcc.t4,
> com.ibm.db2.jcc.uw,
> com.mysql.jdbc,
> com.mysql.jdbc.log,
> javassist,
> javassist.bytecode,
> javassist.compiler,
> javassist.convert,
> javassist.expr,
> javassist.runtime,
> javassist.tools,
> javassist.util,
> javax.sql,
> javax.transaction,
> javax.xml.parsers,
> jsx3,
> jsx3.app,
> jsx3.chart,
> jsx3.gui,
> jsx3.gui.matrix,
> jsx3.html,
> jsx3.lang,
> jsx3.net,
> jsx3.util,
> jsx3.vector,
> jsx3.xml,
> net.sf.ehcache,
> org.apache.log4j,
> org.dom4j,
> org.dom4j.bean,
> org.dom4j.datatype,
> org.dom4j.dom,
> org.dom4j.dtd,
> org.dom4j.io,
> org.dom4j.jaxb,
> org.dom4j.rule,
> org.dom4j.swing,
> org.dom4j.tree,
> org.dom4j.util,
> org.dom4j.xpath,
> org.dom4j.xpp,
> org.gjt.mm.mysql,
> org.hibernate,
> org.hibernate.cfg,
> org.hibernate.hql,
> org.hibernate.id,
> org.hibernate.impl,
> org.hibernate.jdbc,
> org.hibernate.jmx,
> org.hibernate.lob,
> org.hibernate.sql,
> org.hibernate.stat,
> org.hibernate.type,
> org.hibernate.util,
> org.jaxen,
> org.jaxen.dom,
> org.jaxen.dom4j,
> org.jaxen.expr,
> org.jaxen.function,
> org.jaxen.javabean,
> org.jaxen.jdom,
> org.jaxen.pattern,
> org.jaxen.saxpath,
> org.jaxen.util,
> org.jaxen.xom,
> org.slf4j,
> org.slf4j.helpers,
> org.slf4j.impl,
> org.slf4j.spi,
> org.w3c.dom,
> org.w3c.dom.css,
> org.w3c.dom.events,
> org.w3c.dom.html,
> org.w3c.dom.ranges,
> org.w3c.dom.views,
> org.xml.sax,
> org.xml.sax.ext,
> sqlj.runtime,
> sqlj.runtime.error,
> sqlj.runtime.ref,
> sqlj.runtime.util,
> Thx.
> David
Re: OSGi running my own embedded Jetty, dependent plugins not starting? [message #591879 is a reply to message #46349] Wed, 11 February 2009 13:10 Go to previous message
Thx.
David
David Wynter wrote:
> (Running)
> (Running)
> (Running)
> Thread] (Running)
> Thread] (Running)
> Thread] (Running)
> Thread] (Running)
> Thread] (Running)
> Thread] (Running)
> (Running)
> classes.
> This one
> Bundle-ClassPath:
> OSGi/Minimum-1.1
> Bundle-ClassPath: .
> antlr-2.7.6.jar,
> db2jcc.jar,
> dom4j-1.6.1.jar,
> dwr.jar,
> ehcache-1.2.3.jar,
> h2-1.1.107.jar,
> hibernate3.jar,
> jdbc2_0-stdext.jar,
> jta-1.1.jar,
> log4j-1.2.15.jar,
> xml-apis.jar
> antlr,
> antlr.ASdebug,
> antlr.actions.cpp,
> antlr.actions.java,
> antlr.build,
> antlr.collections,
> antlr.debug,
> antlr.debug.misc,
> antlr.preprocessor,
> com.ibm.db2.jcc,
> com.ibm.db2.jcc.a,
> com.ibm.db2.jcc.b,
> com.ibm.db2.jcc.t2,
> com.ibm.db2.jcc.t4,
> com.ibm.db2.jcc.uw,
> com.mysql.jdbc,
> com.mysql.jdbc.log,
> javassist,
> javassist.bytecode,
> javassist.compiler,
> javassist.convert,
> javassist.expr,
> javassist.runtime,
> javassist.tools,
> javassist.util,
> javax.sql,
> javax.transaction,
> javax.xml.parsers,
> jsx3,
> jsx3.app,
> jsx3.chart,
> jsx3.gui,
> jsx3.gui.matrix,
> jsx3.html,
> jsx3.lang,
> jsx3.net,
> jsx3.util,
> jsx3.vector,
> jsx3.xml,
> net.sf.ehcache,
> org.apache.log4j,
> org.dom4j,
> org.dom4j.bean,
> org.dom4j.datatype,
> org.dom4j.dom,
> org.dom4j.dtd,
> org.dom4j.io,
> org.dom4j.jaxb,
> org.dom4j.rule,
> org.dom4j.swing,
> org.dom4j.tree,
> org.dom4j.util,
> org.dom4j.xpath,
> org.dom4j.xpp,
> org.gjt.mm.mysql,
> org.hibernate,
> org.hibernate.cfg,
> org.hibernate.hql,
> org.hibernate.id,
> org.hibernate.impl,
> org.hibernate.jdbc,
> org.hibernate.jmx,
> org.hibernate.lob,
> org.hibernate.sql,
> org.hibernate.stat,
> org.hibernate.type,
> org.hibernate.util,
> org.jaxen,
> org.jaxen.dom,
> org.jaxen.dom4j,
> org.jaxen.expr,
> org.jaxen.function,
> org.jaxen.javabean,
> org.jaxen.jdom,
> org.jaxen.pattern,
> org.jaxen.saxpath,
> org.jaxen.util,
> org.jaxen.xom,
> org.slf4j,
> org.slf4j.helpers,
> org.slf4j.impl,
> org.slf4j.spi,
> org.w3c.dom,
> org.w3c.dom.css,
> org.w3c.dom.events,
> org.w3c.dom.html,
> org.w3c.dom.ranges,
> org.w3c.dom.views,
> org.xml.sax,
> org.xml.sax.ext,
> sqlj.runtime,
> sqlj.runtime.error,
> sqlj.runtime.ref,
> sqlj.runtime.util,
> Thx.
> David
Previous Topic:How to test my plugin
Next Topic:Why the Unpack the plug-in archive after the installation doesn't work?
Current Time: Mon Sep 01 00:31:41 EDT 2025
Powered by FUDForum. Page generated in 0.03330 seconds
