Home » Language IDEs » ServerTools (WTP) » IBM Contribution Problem
IBM Contribution Problem [message #46332] Tue, 28 September 2004 14:33 Go to next message
Originally posted by:
I installed IBM's contribution accroding to the guide.
After I installed it, I found no those tools show up. I go to check the
configuraion of the Eclipse.
I found:
1. There is problem with com.ibm.wtp.sdk 6.0.0
2. And more specifically, there is problem in web Tooling Platform 6.0.0
3. When I drilled down, the problem is in Server Tools Feature 6.0.0
4. And I checked the property of ths feature, I found the following message
No plug-in: "org.eclipse.monitor.core" included at runtime.
No plug-in: "org.eclipse.monitor.ui" included at runtime.
No plug-in: "org.eclipse.webbrowser" included at runtime.
I am not sure what went wrong. Appreciate your help.
Eric
[Updated on: Mon, 19 November 2012 19:51] by Moderator
Re: IBM Contribution Problem -- i have the same problem [message #46854 is a reply to message #46332] Wed, 29 September 2004 09:36 Go to previous messageGo to next message
I have the same problem and it really wasted me 2 days. Can someone help?
> configuraion of the Elcipse.
> I found:
> Eric
[Updated on: Mon, 19 November 2012 19:52] by Moderator
Re: IBM Contribution Problem -- i have the same problem [message #46883 is a reply to message #46332] Wed, 29 September 2004 09:36 Go to previous messageGo to next message
> I found:
> Eric
[Updated on: Mon, 19 November 2012 19:53] by Moderator
Re: IBM Contribution Problem [message #47398 is a reply to message #46332] Fri, 01 October 2004 09:26 Go to previous message
I have to mention that I have installed Eclipse's version of the WebTools
before I install IBM's. I disabled them before the IBM's was installed, is
that affect the things?
BTW, I can see the plug-in folder under c:\eclipse\plugins\, can I
manuallly change the configuration so that Eclipse can config them well?
How then?
Or should I re-install everything?
I am looking for any kind of advice.
THanks
Eric
> I found:
> Eric
Previous Topic:milestones dates
Next Topic:Missing optionally required plug-in org.eclipse.perfmsr.core_0.0.0
Current Time: Mon Jul 21 21:47:44 EDT 2025
Powered by FUDForum. Page generated in 0.04960 seconds
