Home » Archived » Visual Editor (VE) » How to get VE to work?
How to get VE to work? [message #46329] Sat, 03 July 2004 19:51 Go to next message
Originally posted by: James_Rome.yahoo.com
I have the release eclipse 3.0 installed on Windows XP.
I downloaded the latest integration build of VE and unzipped it in c:\ so the
files go into c:\eclipse.
But, if I right-click on a file and do open with... the visual editor choice
does not appear. Is there some other way to install this?
Jim
Re: How to get VE to work? [message #46359 is a reply to message #46329] Sat, 03 July 2004 22:17 Go to previous messageGo to next message
> the files go into c:\eclipse.
> choice does not appear. Is there some other way to install this?
> Jim
You have to install emf and gef - version for your vep version -
links for downlod gef and emf are together with vep
regards
Re: How to get VE to work? [message #49316 is a reply to message #46329] Sat, 10 July 2004 16:50 Go to previous message
> so the files go into c:\eclipse.
> Jim
I needed to edit the configuration file in configuration/org.eclipse.update
Re: How to get VE to work? [message #593898 is a reply to message #46329] Sat, 03 July 2004 22:17 Go to previous message
> Jim
regards
Re: How to get VE to work? [message #594919 is a reply to message #46329] Sat, 10 July 2004 16:50 Go to previous message
> Jim
Previous Topic:VE Swing Problem: BoxLayout can't be shared
Next Topic:VE Bean JLabel generates another code as JCheckBox
Current Time: Sun Aug 31 08:32:09 EDT 2025
Powered by FUDForum. Page generated in 0.06801 seconds
