Home » Language IDEs » PHP Development Tools (PDT) » Posted a couple of debug bugs/enancements
Posted a couple of debug bugs/enancements [message #46328] Fri, 24 August 2007 19:20 Go to next message
Enancement
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201153
Bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201155
I still asking if the fact that when I save a file sometime the breakpoints
are removed is a bug.
Someone can tell me why when I terminate a web script debug a new localhost
page are launced in the browser?
Re: Posted a couple of debug bugs/enancements [message #46856 is a reply to message #46328] Tue, 28 August 2007 06:21 Go to previous messageGo to next message
I am assuming you are using xdebug as you don't state in your append which
debugger you are using.
With XDebug your browser holds a cookie while it is debugging web scripts. When
you terminate the debug session, the debug cookie should be removed from the browser
to do this the xdebug client relaunches the original script whith the XDEBUG_SESSION_STOP
to remove the cookie. The eclipse API doesn't (or at least didn't, have not tried 3.3 yet)
to be able to reuse the original tab in firefox for example to open this page but opens
a new tab. You don't get this behaviour if you used the internal web browser. For me though
under 3.3 this option is greyed out.
Dave Kelsey
Fabio wrote:
> Enancement
> Bug
Re: Posted a couple of debug bugs/enancements [message #47341 is a reply to message #46856] Tue, 28 August 2007 10:49 Go to previous messageGo to next message
"Dave Kelsey" <dkel50@hotmail.com> ha scritto nel messaggio
news:fb0sun$gs9$1@build.eclipse.org...
> When
> the browser
> XDEBUG_SESSION_STOP
> not tried 3.3 yet)
> page but opens
Yes, I use Firefox with multiple tabs.
The really bad behavior is that it opens a new tab.
But I cannot avoid this with some settings?
Thanks again
Today Firefox give 2 bugs that I thinked was of PDT... :)
Re: Posted a couple of debug bugs/enancements [message #47359 is a reply to message #47341] Tue, 28 August 2007 11:07 Go to previous messageGo to next message
I wasn't possible with Eclipse 3.2. I don't know if it is possible to achieve
this with eclipse 3.3, it would require a code change so you cannot avoid this.
There are 2 alternatives which may help
1. Select eclipse to use the internal browser, and you won't see the problem
2. You can disconnect while in the middle of debugging rather than stopping
to disconnect select either the top entry in the debug view (a server with
the text [PHP Web Page] or the next entry down which says "PHP Application"
and press the disconnect button which is the one to the right of the stop button.
This will stop the debug, but leave your browser in debug mode and leave eclipse
in debugging mode, but won't create a new tab.
Dave Kelsey
>> When
>> the browser
>> XDEBUG_SESSION_STOP
>> not tried 3.3 yet)
>> page but opens
> Thanks again
Re: Posted a couple of debug bugs/enancements [message #49531 is a reply to message #46328] Thu, 06 September 2007 17:01 Go to previous message
Originally posted by: codeslave.ca.ibm.com
If you're on Linux, this is a known bug in the SWT browser.
You can disable this effect by using an external browser (Firefox,
Konqueror, etc.).
https://bugs.eclipse.org/bugs/show_bug.cgi?id=194471
Nick
Previous Topic:Error opening editor
Next Topic:where is PHP perspective?
Current Time: Sun Aug 31 08:32:23 EDT 2025
Powered by FUDForum. Page generated in 0.04378 seconds
