Home » Eclipse Projects » Mylyn » Reverse order on Bugzilla comments
Reverse order on Bugzilla comments [message #46279] Mon, 31 March 2008 02:44 Go to next message
Hi there,
I am using eclipse Europa (Version: 3.3.2, Build id: M20080221-1800) with
the latest Mylyn (2.3.1.v20080312-1300) and the Bugzilla (2.20) connector.
For some bugs the ordering seems to be reversed, i.e. the last comment is
shown as description and the description as last comment. Everything in
between is also reversed. Is this a known bug?
regards
Markus
Re: Reverse order on Bugzilla comments [message #46310 is a reply to message #46279] Mon, 31 March 2008 14:45 Go to previous messageGo to next message
eclipse@gitteundmarkus.de (Markus Plail) wrote:
> Hi there,
> regards
> Markus
What are your settings in ../userprefs.cgi for "When viewing a bug, show
comments in this order" and what Version of Bugzilla do you use.
If I remember correctly you must set this setting to "Site Default".
I saw this when I implement the patch for "Bug editor assumes comment ordering
is such that the description is always the first comment"
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=165968)
regards
Frank
Re: Reverse order on Bugzilla comments [message #46341 is a reply to message #46310] Tue, 01 April 2008 04:21 Go to previous messageGo to next message
Bugzilla version is 2.20 as mentioned above. My preference for ordering is
'Site default'.
BTW: This behaviour is not consistent. For some bugs the order is correct
and for some it is reversed.
ordering
OK, read through it seems like a good idea to allow sorting. Unfortunately
it is not in the 2.3 releases.
regards
Markus
Re: Reverse order on Bugzilla comments [message #47623 is a reply to message #46341] Sat, 26 April 2008 12:02 Go to previous message
Originally posted by: rob.elves.eclipse.org
> Unfortunately it is not in the 2.3 releases.
fyi, sort order will be included in the 3.0 release (June 25).
-Rob
Re: Reverse order on Bugzilla comments [message #588768 is a reply to message #46279] Mon, 31 March 2008 14:45 Go to previous message
> Hi there,
> regards
> Markus
regards
Frank
Re: Reverse order on Bugzilla comments [message #588776 is a reply to message #46310] Tue, 01 April 2008 04:21 Go to previous message
'Site default'.
ordering
regards
Markus
Re: Reverse order on Bugzilla comments [message #589260 is a reply to message #46341] Sat, 26 April 2008 12:02 Go to previous message
-Rob
Previous Topic:JIRA custom attributes
Next Topic:[2.3.1] [Task List] Clear button doesn't work anymore
Current Time: Mon Jul 21 21:58:03 EDT 2025
Powered by FUDForum. Page generated in 0.25540 seconds
