Home » Archived » Visual Editor (VE) » Creation fails
Creation fails [message #46254] |
Sat, 03 July 2004 16:30  |
Originally posted by: Mr4U.gmx.net
Hi!
What can I do if I get the following message when creating a JApplet
(etc) Class:
Creation of element failed.
Attempting to beginRule: F/aufg111/aufg111, does not match outer scope
rule: L/aufg111/aufg111/Aufg111.java
Thank you in advance.
(Please do not be angry, since I am a beginner with eclipse)
-AS
Re: Creation fails [message #46688 is a reply to message #46446] |
Sun, 04 July 2004 10:15   |
Andreas,
The latest stable build of VE (S20040628) runs on Eclipse 3.0 final, GEF
3.0 and EMF 2.0.
- Jeff
Andreas Schöneck wrote:
> Hi Jeff,
> thanks for this hint. That was what I nearly thought already. That means
> for me to wait for a version which is compliant with any versions of
> Eclipse 3.x and so on.
> AS
> Jeff Myers wrote:
>> Hi Andreas,
>> Please make sure the versions of VE, Eclipse, GEF and EMF you
>> installed match the requirements listed on the download page of VE.
>> This error usually occurs when you're running a version of VE that is
>> incompatible with the version of Eclipse (ie running VE 1.0 M1 on
>> Eclipse 3 final, etc)
>> - Jeff
>>> Hi!
>>> (etc) Class:
>>> scope rule: L/aufg111/aufg111/Aufg111.java
>>> -AS
Re: Creation fails [message #51106 is a reply to message #46688] |
Wed, 21 July 2004 11:05   |
Jeff,
that does indeed work fine for me.
Nevertheless VE has some minor bugs, like sometimes not showing the
layout (and making addition of cotrols unavailable)
AS
Jeff Myers wrote:
> Andreas,
> 3.0 and EMF 2.0.
> - Jeff
>> Hi Jeff,
>> means for me to wait for a version which is compliant with any
>> versions of Eclipse 3.x and so on.
>> AS
>> Jeff Myers wrote:
>>> Hi Andreas,
>>> - Jeff
>>>> Hi!
>>>> (etc) Class:
>>>> -AS
Re: Creation fails [message #51134 is a reply to message #51106] |
Wed, 21 July 2004 11:18  |
Andreas,
Glad that it's working for you. Please open bug reports for problems
you find with the VE. Include a detailed description of the scenario
that causes the problem (that is hopefully reproducible) and any errors
that show up in the .log file in the .metadata directory in your workspace.
- Jeff
> Jeff,
> AS
> Jeff Myers wrote:
>> Andreas,
>> GEF 3.0 and EMF 2.0.
>> - Jeff
Re: Creation fails [message #593867 is a reply to message #46254] |
Sat, 03 July 2004 17:43  |
Hi Andreas,
Please make sure the versions of VE, Eclipse, GEF and EMF you installed
match the requirements listed on the download page of VE. This error
usually occurs when you're running a version of VE that is incompatible
with the version of Eclipse (ie running VE 1.0 M1 on Eclipse 3 final, etc)
- Jeff
> Hi!
> (etc) Class:
> -AS
Re: Creation fails [message #593946 is a reply to message #46300] |
Sun, 04 July 2004 07:36  |
Hi Jeff,
AS
Jeff Myers wrote:
> Hi Andreas,
> - Jeff
>> Hi!
>> (etc) Class:
>> -AS
Re: Creation fails [message #594005 is a reply to message #46446] |
Andreas,
3.0 and EMF 2.0.
- Jeff
> Hi Jeff,
> AS
> Jeff Myers wrote:
>> Hi Andreas,
>> - Jeff
>>> Hi!
>>> (etc) Class:
>>> -AS
Re: Creation fails [message #595545 is a reply to message #46688] |
Jeff,
AS
Jeff Myers wrote:
> Andreas,
> 3.0 and EMF 2.0.
> - Jeff
>> Hi Jeff,
>> AS
>> Jeff Myers wrote:
>>> Hi Andreas,
>>> - Jeff
>>>> Hi!
>>>> (etc) Class:
>>>> -AS
Re: Creation fails [message #595551 is a reply to message #51106] |
Andreas,
- Jeff
> Jeff,
> AS
> Jeff Myers wrote:
>> Andreas,
>> - Jeff
Current Time: Sun Aug 31 01:53:01 EDT 2025
Powered by FUDForum. Page generated in 0.04506 seconds
