Home » Archived » Visual Editor (VE) » Creation fails
Creation fails [message #46254] Sat, 03 July 2004 16:30 Go to next message
Originally posted by: Mr4U.gmx.net
Hi!
What can I do if I get the following message when creating a JApplet
(etc) Class:
Creation of element failed.
Attempting to beginRule: F/aufg111/aufg111, does not match outer scope
rule: L/aufg111/aufg111/Aufg111.java
Thank you in advance.
(Please do not be angry, since I am a beginner with eclipse)
-AS
Re: Creation fails [message #46300 is a reply to message #46254] Sat, 03 July 2004 17:43 Go to previous messageGo to next message
Hi Andreas,
Please make sure the versions of VE, Eclipse, GEF and EMF you installed
match the requirements listed on the download page of VE. This error
usually occurs when you're running a version of VE that is incompatible
with the version of Eclipse (ie running VE 1.0 M1 on Eclipse 3 final, etc)
- Jeff
Andreas Schöneck wrote:
> Hi!
> (etc) Class:
> -AS
Re: Creation fails [message #46446 is a reply to message #46300] Sun, 04 July 2004 07:36 Go to previous messageGo to next message
Hi Jeff,
thanks for this hint. That was what I nearly thought already. That means
for me to wait for a version which is compliant with any versions of
Eclipse 3.x and so on.
AS
Jeff Myers wrote:
> Hi Andreas,
> - Jeff
>> Hi!
>> (etc) Class:
>> -AS
Re: Creation fails [message #46688 is a reply to message #46446] Sun, 04 July 2004 10:15 Go to previous messageGo to next message
Andreas,
The latest stable build of VE (S20040628) runs on Eclipse 3.0 final, GEF
3.0 and EMF 2.0.
- Jeff
> Hi Jeff,
> AS
> Jeff Myers wrote:
>> Hi Andreas,
>> installed match the requirements listed on the download page of VE.
>> This error usually occurs when you're running a version of VE that is
>> incompatible with the version of Eclipse (ie running VE 1.0 M1 on
>> - Jeff
>>> Hi!
>>> (etc) Class:
>>> scope rule: L/aufg111/aufg111/Aufg111.java
>>> -AS
Re: Creation fails [message #51106 is a reply to message #46688] Wed, 21 July 2004 11:05 Go to previous messageGo to next message
Jeff,
that does indeed work fine for me.
Nevertheless VE has some minor bugs, like sometimes not showing the
layout (and making addition of cotrols unavailable)
AS
Jeff Myers wrote:
> Andreas,
> 3.0 and EMF 2.0.
> - Jeff
>> Hi Jeff,
>> means for me to wait for a version which is compliant with any
>> versions of Eclipse 3.x and so on.
>> AS
>> Jeff Myers wrote:
>>> Hi Andreas,
>>> - Jeff
>>>> Hi!
>>>> (etc) Class:
>>>> -AS
Re: Creation fails [message #51134 is a reply to message #51106] Wed, 21 July 2004 11:18 Go to previous message
Andreas,
Glad that it's working for you. Please open bug reports for problems
you find with the VE. Include a detailed description of the scenario
that causes the problem (that is hopefully reproducible) and any errors
that show up in the .log file in the .metadata directory in your workspace.
- Jeff
> Jeff,
> AS
> Jeff Myers wrote:
>> Andreas,
>> GEF 3.0 and EMF 2.0.
>> - Jeff
Re: Creation fails [message #593867 is a reply to message #46254] Sat, 03 July 2004 17:43 Go to previous message
Hi Andreas,
- Jeff
> Hi!
> (etc) Class:
> -AS
Re: Creation fails [message #593946 is a reply to message #46300] Sun, 04 July 2004 07:36 Go to previous message
Hi Jeff,
AS
Jeff Myers wrote:
> Hi Andreas,
> - Jeff
>> Hi!
>> (etc) Class:
>> -AS
Re: Creation fails [message #594005 is a reply to message #46446] Sun, 04 July 2004 10:15 Go to previous message
Andreas,
3.0 and EMF 2.0.
- Jeff
> Hi Jeff,
> AS
> Jeff Myers wrote:
>> Hi Andreas,
>> - Jeff
>>> Hi!
>>> (etc) Class:
>>> -AS
Re: Creation fails [message #595545 is a reply to message #46688] Wed, 21 July 2004 11:05 Go to previous message
Jeff,
AS
Jeff Myers wrote:
> Andreas,
> 3.0 and EMF 2.0.
> - Jeff
>> Hi Jeff,
>> AS
>> Jeff Myers wrote:
>>> Hi Andreas,
>>> - Jeff
>>>> Hi!
>>>> (etc) Class:
>>>> -AS
Re: Creation fails [message #595551 is a reply to message #51106] Wed, 21 July 2004 11:18 Go to previous message
Andreas,
- Jeff
> Jeff,
> AS
> Jeff Myers wrote:
>> Andreas,
>> - Jeff
Previous Topic:Can't get SWT Widgets in VE
Next Topic:Can't get VE to work on MacOS X
Current Time: Sun Aug 31 04:27:36 EDT 2025
Powered by FUDForum. Page generated in 0.04779 seconds
