Home » Language IDEs » Java Development Tools (JDT) » Adding JRE container to classpath?
Adding JRE container to classpath? [message #46241] Sun, 01 June 2003 15:34 Go to next message
Originally posted by: objectiveous.yahoo.com
Folks,
I've create a new project wizard for my development team and I need to add
the JRE container to the classpath. I've been poking arounf in
org.eclipse.jdt.ui.wizards but can't seem to grok how to get the following
added into .classpath:
<classpathentry kind="con" path="org.eclipse.jdt.launching.JRE_CONTAINER"/>
Thanks in advance.
Re: Adding JRE container to classpath? [message #47261 is a reply to message #46241] Tue, 03 June 2003 08:43 Go to previous message
Use JavaRuntime.getDefaultJREContainerEntry() to get the IClasspath
entry. (to use with IJavaProject.setRawClasspath())
Note that you can also simply add the JavaCapabilityConfigurationPage as
an additional page to your project wizard and give the user to preview
the settings. The page adds the correct JRE entry (container or variable
as specified by the user) and on finish you can call this page to config
the Java nature including class path.
As a complete example on how to use the JavaCapabilityConfigurationPage,
see MyProjectCreationWizard from the org.eclipse.jdt.ui.tests plugin.
Martin
Rob Evans wrote:
> Folks,
> Thanks in advance.
Previous Topic:Name of a PackageFragmentRoot
Next Topic:Overriding preferences in Eclipse.
Current Time: Sun Aug 31 15:55:05 EDT 2025
Powered by FUDForum. Page generated in 0.03915 seconds
