Home » Modeling » OCL » java.lang.ClassCircularityError: myPackage/ValidationDelegateClientSelector
java.lang.ClassCircularityError: myPackage/ValidationDelegateClientSelector [message #46239] Mon, 10 December 2007 06:55 Go to next message
When EMF Validation examples are not loaded, the exception occurs. When
EMF Validation examples are loaded, the exception does not occur.
Any idea on the reason for this would be appreciated.
Eclipse Version: 3.3.0 Build id: I20070621-1340
Sun JRE 1.6.02
EMF Validation 1.1.1 200708161445
What I have read so far on ClassCircularityError seems irrelevant (given
the previously mentionned version numbers).
Loïc
mypackage/validation/constraints/ValidationDelegateClientSel ector
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:161)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:501)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:471)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:430)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:413)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.emf.validation.internal.service.ClientContext.in itializeCustomSelector(ClientContext.java:186)
org.eclipse.emf.validation.internal.service.ClientContext.in itializeSelector(ClientContext.java:122)
org.eclipse.emf.validation.internal.service.ClientContext.<init >(ClientContext.java:72)
org.eclipse.emf.validation.internal.service.ClientContextMan ager.configureClientContexts(ClientContextManager.java:321)
org.eclipse.emf.validation.internal.service.ClientContextMan ager.configureConstraintBindings(ClientContextManager.java:3 04)
org.eclipse.emf.validation.internal.EMFModelValidationPlugin $Implementation.configureConstraintBindings(EMFModelValidati onPlugin.java:256)
org.eclipse.emf.validation.internal.EMFModelValidationPlugin $Implementation.start(EMFModelValidationPlugin.java:229)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
[Validation] Re: java.lang.ClassCircularityError: myPackage/ValidationDelegateClientSelector [message #46297 is a reply to message #46239] Mon, 10 December 2007 08:16 Go to previous message
Hi, Loïc,
This is an EMF Validation Framework question, so I have replied to that
newsgroup.
Are you trying to re-use the client-context defined by the example?
This problem has come up a few times before in the EMF newsgroup, so you
might search for possible solutions (or is that what you meant by "what
[you] have read so far?")
One work-around that I recall having some success is to exclude the package
in which the client-context selector is defined from the lazy-start header
in the bundle manifest.
HTH,
Christian
> Sun JRE 1.6.02
> Loïc
-----8<-----
Previous Topic:null as value in OCL?
Next Topic:OCL Invariants on Ecore /EMF
Current Time: Thu Jul 24 02:25:12 EDT 2025
Powered by FUDForum. Page generated in 1.82844 seconds
