Home » Modeling » TMF (Xtext) » Cross reference items not available in .chk files
Cross reference items not available in .chk files [message #46237] Fri, 29 May 2009 08:03 Go to next message
I'm trying to write checks (.chk file) for a model that contains cross
references to an another grammar/model. It looks like the cross references
are not available in the .chk file. No code completion for them and marked
as "unknown properties". For Example:
import myDslB;
context Attribute ERROR "Error" : type; // more to come here
Where "type" is a cross reference to another grammar and marked as an
error in the .chk editor. I also recognized a problem with the generated
ecore file. When opening it with the ecore editor and navigating to a
cross reference item, it gives
Problems encounterd in file "classpath:/org/xtext/example/MyDslA.ecore"
java.net.MalformedURLException: unknown protocol: classpath
Any ideas?
Christoph
P.S.: The grammars are:
grammar org.xtext.example.MyDslA with org.eclipse.xtext.common.Terminals
generate myDslA "http://www.xtext.org/example/MyDslA"
Model :
(imports+=Import)*
(datatypes+=DataType)*;
Import :
'import' importURI=STRING;
DataType:
'datatype' name=ID ';'?;
grammar org.xtext.example.MyDslB with org.eclipse.xtext.common.Terminals
import "classpath:/org/xtext/example/MyDslA.ecore" as MyDslA
generate myDslB "http://www.xtext.org/example/MyDslB"
Model :
(imports+=Import)*
(classes+=Class);
Import :
Class :
'class' name=ID '{'
properties+=Property*
Property:
Attribute | Reference;
Attribute:
'attr' name=ID ':' type=[MyDslA::DataType] ';'?;
Reference:
'ref' name=ID ':' type=[Class] ';'?;
Re: Cross reference items not available in .chk files [message #46325 is a reply to message #46237] Fri, 29 May 2009 08:18 Go to previous messageGo to next message
Referencing ecore files using the classpath scheme is not good, since
resource sets need to be configured with a special URIConverter in order
to be able resolve classpath URIs.
EMF and so Xpand both do not support classpath URIs.
You should instead use a platform:/resource URI.
Sven
Christoph Kulla schrieb:
> references are not available in the .chk file. No code completion for
> them and marked as "unknown properties". For Example:
> import myDslB;
> Any ideas?
> Christoph
> Model :
> (imports+=Import)*
> Import :
> DataType:
> Model :
> (imports+=Import)*
> (classes+=Class);
> Import :
> Class :
> 'class' name=ID '{'
> Property:
> Attribute:
> Reference:
Re: Cross reference items not available in .chk files [message #46385 is a reply to message #46325] Fri, 29 May 2009 08:46 Go to previous messageGo to next message
thanks Sven. I just used the "classpath:/" scheme as the documentation
says this it is the preferred way. I think it would be good when the
documentation lists the several schemes with their pro and cons.
Christoph
Re: Cross reference items not available in .chk files [message #46480 is a reply to message #46385] Fri, 29 May 2009 16:33 Go to previous message
Yes, we just recently (because of the bug you submitted) realized that
the classpath scheme has its problems.
We'll update the documentation ASAP.
Sven
> Christoph
Previous Topic:[XText] problem in importing a metamodel.
Next Topic:[AText] a question releated to removing left recursion.
Current Time: Tue Jul 22 02:29:24 EDT 2025
Powered by FUDForum. Page generated in 0.24519 seconds
