Please Help -Using EMFT Validation in GMF [message #46235] |
Tue, 22 August 2006 14:21 |
Originally posted by: senthil.periasamy.flextronicssoftware.com
Hi ,
I want to validate my model using EMF validation framework.
If i have to achieve this using GMF(i.e, EMF validation invoked through
GMF).
Pls let me know if this is possible, and if possible how should i go about
achieving the same.
can i make use of the org.eclipse.emf.validation.constraintProviders
extension in
the GMF projects plugin.xml to define my project specific constraints.
Is it possible to register the constraints of the model (EMF model) with
validation service through GMF's plugin.xml file.
Senthil
Re: Please Help -Using EMFT Validation in GMF [message #46267 is a reply to message #46235] |
Tue, 22 August 2006 14:35 |
Senthil,
When posting the same question to multiple newsgroups, please use a
single posting so that an answer on any group is an answer on all groups.
Senthil wrote:
> Hi ,
> through GMF).
> about achieving the same.
> extension in the GMF projects plugin.xml to define my project specific
> constraints.
> with validation service through GMF's plugin.xml file.
> Regards
> Senthil
Re: Please Help -Using EMFT Validation in GMF [message #586020 is a reply to message #46235] |
Ed Merks Messages: 33217 Registered: July 2009 |
Senthil,
Senthil wrote:
> Hi ,
> through GMF).
> constraints.
> Regards
> Senthil
Ed Merks
FUDForum. Page generated in 0.04113 seconds
