Home » Newcomers » Newcomers » Include RMI Stubs in Eclipse generated JAR
Include RMI Stubs in Eclipse generated JAR [message #4031] Mon, 17 January 2005 22:04 Go to next message
Originally posted by: dstamenkovic.audioproducts.com.au.nospam
Hey
I've just gotten my java website sorted out to use eclipse along with
nitrox which I'm really happy about because in the past I've had to
compile and deploy manually.
However Im using RMI in my site and I have RMI generated stub classfiles
(with command RMIC -v1.2 au.com.audioproducts.package.classname
These stubs go into the proper package directory but Eclipse excludes them
from the jar it generates when I select export project.
Is there any way I can include them because this will stop me from being
able to launch my site from within Eclipse(tomcat)
Dejan
Re: Include RMI Stubs in Eclipse generated JAR [message #4729 is a reply to message #4031] Tue, 18 January 2005 09:52 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
When you export a project, the Java source is compiled into a temporary
output directory.
If you generate a build.xml file from the plugin.xml (see the PDE context
menu), you can see what it does.
The proper solution is to generate a library jar that contains the RMI stub
classes and add the library to your project.
See http://www.eclipsefaq.org/chris/faq/html/faq105.html for an explanation
how to do that.
Chris Laffra, http://eclipsefaq.org
"Dejan" <dstamenkovic@audioproducts.com.au.nospam> wrote in message
news:cshuc1$rgf$1@www.eclipse.org...
> Hey
> Thanks
> Dejan
Re: Include RMI Stubs in Eclipse generated JAR [message #11238 is a reply to message #4729] Fri, 21 January 2005 09:08 Go to previous message
It is possible that the stubs are not included because the workspace is
out of sync with the filesystem.
You can either enable automatic file system synchronization (in the
workbench properites page), or
if you use ant build file, you can select an option that will sync with
the filesystem after the script is run.
I can also suggest using the RMI Plugin for Eclipse - the plugin will
take care of all the stubs generation stuff,
and it has other features such as the RMI Launcher and the Registry
Inspector.
More information at http://www.genady.net/rmi/v16/
Screenshots at http://www.genady.net/rmi/v16/screenshots/
Personal (free), educational and commercial licenses are available.
Genady Beryozkin
>output directory.
>how to do that.
Previous Topic:a question about Eclipse---Linux (AMD 64/GTK 2)
Next Topic:Unable to create Java project
Current Time: Sun Jul 13 16:51:06 EDT 2025
Powered by FUDForum. Page generated in 0.08236 seconds
