Home » Modeling » OCL » Customizing OCL Environment...
Customizing OCL Environment... [message #46177] |
Sun, 09 December 2007 19:22  |
Originally posted by: asma.charfi.com
I folowed the example in the "OCL Developer Guide-> Programmer's Guide->
Advanced Topics-> Customizing the Environment->Defining Helper Operation in
Java" topic.
I added two operations, the example works perfectly (I can parse constraints
using my two new operations)
Now I want to use the same process, but to customize UMLEnvironment not
Ecore one.
I changed all classes used in this example: for example:
class MyEnvironment extends UMLEnvironment instead of class
MyEnvironment extends EcoreEnvironment
class MyEvaluationEnvironment extends UMLEvaluationEnvironment instead
of class MyEvaluationEnvironment extends EcoreEvaluationEnvironment....
I changed also method signature to use UML parameter instead of Ecore one.
for example I canged the operation type in the method callOperation().
public Object callOperation(org.eclipse.uml2.uml.Operation operation, int
opcode, Object source, Object[] args) //not EOperation.
When I parse the constraint that contains my operation (regexMach), I get
this error: : Cannot call operation (regexMatch) because it is not a query.
the instruction addOperation(getOCLStandardLibrary().getString(),
regexMatch); was passed (without error)
so I think that problem comes from MyEvaluationEnvironment and not
MyEnvironment class. (problem in call operation and not in
definecustomsoperations())
Could some one help me?
thanks!
Re: Customizing OCL Environment... [message #46327 is a reply to message #46177] |
Mon, 10 December 2007 08:19   |
Hi, Asma,
The UML Operation that your custom UMLEnvironment creates must be designated
as a "query" operation in order to OCL to guarantee that a constraint
evaluation will not have side-effects in the modeled system.
Before invoking addOperation(...) simply set your operation as a query using
Operation::setIsQuery(boolean) method.
Christian
charfi asma wrote:
> in Java" topic.
> constraints using my two new operations)
> Ecore one.
> instead
> EcoreEvaluationEnvironment.... I changed also method signature to use UML
> parameter instead of Ecore one. for example I canged the operation type in
> the method callOperation(). public Object
> query.
> thanks!
Re: Customizing OCL Environment... [message #46420 is a reply to message #46327] |
Wed, 12 December 2007 19:32   |
Hi christian,
thank you very much, it works but I still have problem with callOperation
method.
My operatoion is added to String. when I evaluate it on s it return
OclInvalid. although in the method code I only put return true
public Object callOperation(Operation operation, int opcode, Object source,
Object[] args)
return true;
[OCL] Evaluate: s
[OCL] Result : ((1,2),(1,3))
[OCL] Evaluate: '^\(\([0-9]+(,[0-9]+)*\)(,\([0-9]+(,[0-9]+)*\))*\)$'
[OCL] Result : ^\(\([0-9]+(,[0-9]+)*\)(,\([0-9]+(,[0-9]+)*\))*\)$
[OCL] Evaluate:
s.regexMatch('^\(\([0-9]+(,[0-9]+)*\)(,\([0-9]+(,[0-9]+)*\)) *\)$')
[OCL] Result : OclInvalid
[OCL] Evaluate: true
[OCL] Result : true
[OCL] Evaluate:
s.regexMatch('^\(\([0-9]+(,[0-9]+)*\)(,\([0-9]+(,[0-9]+)*\)) *\)$').=(true)
[OCL] Result : false
It seems like the new operation is not recongnized.
is the annotation of the operation has an impact? in fact when I change all
Ecore concept to UML one, I did not change EAnotation.
I don't know the equivalent of EAnnotation in UML so I keep this code in my
defineCustomOperations method
EAnnotation annotation = EcoreFactory.eINSTANCE.createEAnnotation();
annotation.setSource("MyEnvironment");
regexMatch.getEAnnotations().add(annotation);
Can you help me?
thank you very much
"Christian W. Damus" <cdamus@ca.ibm.com> a
Re: Customizing OCL Environment... [message #46635 is a reply to message #46420] |
Thu, 13 December 2007 09:40   |
Hi, Asma,
I'd suggest putting a breakpoint at the top of the
EvaluationVisitorImpl::visitCallOperationExp(...)
method to see where an exception is occurring (which would result in
OclInvalid) or where OclInvalid is being returned for some other reason.
I don't have any suggestion off-hand for why this wouldn't work.
Christian
charfi asma wrote:
> Hi christian,
> method.
> return true;
> [OCL] Evaluate: s
> [OCL] Evaluate:
> [OCL] Result : true
> [OCL] Evaluate:
> all Ecore concept to UML one, I did not change EAnotation.
> my
> Can you help me?
> thank you very much
> "Christian W. Damus" <cdamus@ca.ibm.com> a �rit dans le message de news:
> fjjed9$nge$3@build.eclipse.org...
>> Hi, Asma,
>> designated
>> using
>> Cheers,
>> Christian
>> charfi asma wrote:
>>> Hi,
>>> in Java" topic.
>>> Ecore one.
>>> instead
>>> UML parameter instead of Ecore one. for example I canged the operation
>>> type in
>>> get this error: : Cannot call operation (regexMatch) because it is not a
>>> query.
>>> thanks!
Re: Customizing OCL Environment... [message #46759 is a reply to message #46727] |
Thu, 13 December 2007 12:12   |
Hi, Asma,
I mean the org.eclipse.ocl.internal.evaluation.EvaluationVisitorImpl class.
The other is only involved in parsing and evaluation using the deprecated
1.0 version of the API.
In general, if you want to check out a consistent set of OCL plug-ins, you
can use the "Team -> Load Map Projects" context-menu action on the
org.eclipse.ocl.releng/maps/ocl.map file. This will load the CVS tags of
all of the OCL projects that were released together, comprising a
consistent baseline.
Or, if you just want to get all of the OCL code from HEAD, you can use the
"Import Project Set..." context-menu action on either of the *.psf files in
the org.eclipse.ocl.releng/psf folder.
HTH,
Christian
charfi asma wrote:
> when I import plugin org.eclipse.emf.ocl to open
> org.eclipse.emf.ocl.expressions.impl.EvaluationVisitorImpl class I did
> not get source (only .class)
> I can not add brakpoint to this method. I got this error (org.eclipse.ocl)
> does not exist when I check it out from cvs.
> how can I do :-(
> thank you
> asma
-----8<-----
Re: Customizing OCL Environment... [message #46781 is a reply to message #46759] |
Thu, 13 December 2007 23:17   |
when I choose "ImportProjectSet" menu on ocl-all.psf I get a window that
require a password!
I put anonymous as username but the import did not succed.
concerning the other way "Team -> Load Map Projects" context-menu action on
the
> org.eclipse.ocl.releng/maps/ocl.map file", I can not find Load Map Project
> in Team.
any way, I did not get the same error now.
In fact My problem was in MyEnvironmentEvaluation. which was not considered
when I run my plugin.
the callOperation was not executed. so I modify the method that create this
class: public MyEvaluationEnvironment createEvaluationEnvironment()
before I put two methods:
public EvaluationEnvironment<Classifier,Operation,Property,Class,EObject >
createEvaluationEnvironment(MyEnvironmentFactory factory)
{return new MyEvaluationEnvironment(factory);}
createEvaluationEnvironment(EvaluationEnvironment<Classifier,Operation,Property,Class,EObject >
parent)
{return new MyEvaluationEnvironment(parent);}
and there for I used two constructors in my MyEvaluationEnvironment().
I find in the UMLEnvironmentFactory 3 methods to
createEvaluationEnvironment() so I use the third one which did not have
parameter. but in MyEvaluationEnvironment I can not put constructor without
parameter (cause it extends UMLEvaluationEnvironment)
so to add a constructor without param (public MyEvaluationEnvironment()
{super(); }) as it is specified in EcoreEvaluationEnvironment, I implement
the interface EvaluationEnvironment instead of extending
UMLEvaluationEnvironment.
when I put all this changes it works! now the calloperation is executed and
it return true if I put return true and false if I put return false. but I
have neu problem in the evaluation method: self =null! (parsing did not
raise error)
--------------------------------------parsing--------------- --------------------------------------------
[OCL] variableExpCS: Variable Expression: self
[OCL] stringLiteralExpCS: String: 'Gaspard::Tiler'
[OCL] operationCallExpCS: getAppliedStereotype
[OCL] stringLiteralExpCS: String: 'fitting'
[OCL] operationCallExpCS: getValue
[OCL] operationCallExpCS: oclAsType
[OCL] variableDeclarationCS: adding variable declaration for s
'^\{\{[0-9]+(,[0-9]+)*\}(,\{[0-9]+(,[0-9]+)*\})*\}$'
[OCL] operationCallExpCS: regexMatch
[OCL] booleanLiteralExpCS: Boolean: true
[OCL] operationCallExpCS: =
--------------------------------------evaluation------------ --------------------------------------------
[OCL] Evaluate: self
[OCL] Result : null
[OCL] Result : null
[OCL] Evaluate: 'Gaspard::Tiler'
[OCL] Result : Gaspard::Tiler
[OCL] Result : null
[OCL] Evaluate: self.getAppliedStereotype('Gaspard::Tiler')
[OCL] Evaluate: 'fitting'
[OCL] Result : fitting
[OCL] Result : null
[OCL] Evaluate: self.getValue(self.getAppliedStereotype('Gaspard::Tiler'),
'fitting')
'fitting').oclAsType(oclstdlib::String)
[OCL] Evaluate: s : String =
[OCL] Result : s
[OCL] Evaluate: s
[OCL] Result : null
[OCL] Evaluate: '^\{\{[0-9]+(,[0-9]+)*\}(,\{[0-9]+(,[0-9]+)*\})*\}$'
[OCL] Result : ^\{\{[0-9]+(,[0-9]+)*\}(,\{[0-9]+(,[0-9]+)*\})*\}$
[OCL] Evaluate:
s.regexMatch('^\{\{[0-9]+(,[0-9]+)*\}(,\{[0-9]+(,[0-9]+)*\}) *\}$')
[OCL] Result : false // cause I put in callOperation return false when I
put return true it is evaluated true.
Did you suggest any modifications?
thank you asma
Re: Customizing OCL Environment... [message #46842 is a reply to message #46781] |
Fri, 14 December 2007 10:12   |
Hi, Asma,
See some comments in-line, below.
HTH,
Christian
charfi asma wrote:
> require a password!
If you're not an Eclipse committer, then you will need to search-and-replace
the occurrences of "extssh" in the PSF file with "pserver"
Only the pserver protocol supports anonymous access.
> on the
>> Project in Team.
Ah. I guess that is provided by the Eclipse Releng Tools plug-in (available
at the bottom of the Eclipse Platform download pages).
> considered when I run my plugin.
> this class: public MyEvaluationEnvironment createEvaluationEnvironment()
> parent)
> without parameter (cause it extends UMLEvaluationEnvironment)
But, the UMLEnvironmentFactory only has two methods for creating evaluation
environments, same as the EcoreEnvironmentFactory. One creates a root
evaluation environment and the other creates a nested evaluation
environment (given some parent).
That should work. But, why not extend UMLEvaluationEnvironment? You only
have to provide a constructor that accepts the UMLEnvironmentFactory and
calls super, and another that accepts a parent environment and also calls
super. If you do this, then you won't have to re-implement all of the
EvaluationEnvironment interface. You will only have to provide the
overrides for your custom operation(s).
Or, at least extend the AbstractEvaluationEnvironment class which provides
an implementation of the variable-value bindings and the evaluation options
map.
> and it return true if I put return true and false if I put return false.
> but I have neu problem in the evaluation method: self =null! (parsing did
> not raise error)
This should only happen if your client application doesn't provide a value
for "self" when it evaluates an OCL expression, or if your
EvaluationEnvironment implementation didn't implement the
add()/getValueOf()/replace()/remove() methods for manipulating the
variable-value bindings.
-----8<-----
Re: Customizing OCL Environment... [message #46930 is a reply to message #46842] |
Mon, 17 December 2007 19:56  |
Hi Christian,
I find the error:-))))
it deals with calloperation method
I did not put
if (operation.getEAnnotation("MyEnvironment") == null) {
System.out.println("il va apeler l'operation de super");
return super.callOperation(operation, opcode, source, args);}
so when OCL want to evaluate self or getAppliedStereotype()...it did not
find super.callOperation() that's why OCL only recognize my new operation
and not other (the default one)
now, I succed in customizing an UMLEnvironment! thank you a lot for your
help!
asma
Current Time: Tue Jul 15 04:37:06 EDT 2025
Powered by FUDForum. Page generated in 0.08987 seconds
