Home » Eclipse Projects » Nebula » Does setSelection(index) on a grid invoke the selectionListener attached to it?
Does setSelection(index) on a grid invoke the selectionListener attached to it? [message #46166] Thu, 10 January 2008 06:17 Go to next message
Hello all,
I have a grid and I have added a Selection Listener to it.
I wanted to know if on executing the following line of code, will this
listener get invoked:
grid.setSelection(index).
My requirement is that, when I set the selection to a gridItem using the
above line of code, the selection listener associated with it should be
invoked.
I have tried this but the selection listener is not getting fired. How can
I invoke the listener?
Any suggestion would be appreciated.
Thanks and Regards,
Asha Subramaniam.
Re: Does setSelection(index) on a grid invoke the selectionListener attached to it? [message #46196 is a reply to message #46166] Thu, 10 January 2008 06:29 Go to previous messageGo to next message
This is common to all SWT-Widget and I think Grid behaves like real
native ones. Setting a selection through code will never trigger an event.
In standard SWT you have to call notifyListener() your own but I don't
know if this is the same in Nebula-Grid.
Tom
Asha Subramaniam schrieb:
> Hello all,
> invoked.
> can I invoke the listener?
> Thanks and Regards,
> Asha Subramaniam.
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Does setSelection(index) on a grid invoke the selectionListener attached to it? [message #46226 is a reply to message #46196] Thu, 10 January 2008 11:00 Go to previous messageGo to next message
Yes its as Tom says. This is the standard SWT pattern. Since its your
code doing the selection (as opposed to the user) then you can do any
follow on processing that you want (or fire the event as Thomas suggests
with notifyListeners()).
-Chris
> Tom
>> Hello all,
>> the above line of code, the selection listener associated with it
>> should be invoked.
>> Thanks and Regards,
>> Asha Subramaniam.
Re: Does setSelection(index) on a grid invoke the selectionListener attached to it? [message #46321 is a reply to message #46226] Fri, 11 January 2008 01:17 Go to previous message
Thanks Tom and Chris,
I will try out the solution.
Asha Subramaniam.
Re: Does setSelection(index) on a grid invoke the selectionListener attached to it? [message #587528 is a reply to message #46166] Thu, 10 January 2008 06:29 Go to previous message
Tom
> Hello all,
> invoked.
> Thanks and Regards,
> Asha Subramaniam.
Re: Does setSelection(index) on a grid invoke the selectionListener attached to it? [message #587544 is a reply to message #46196] Thu, 10 January 2008 11:00 Go to previous message
-Chris
> Tom
>> Hello all,
>> should be invoked.
>> Thanks and Regards,
>> Asha Subramaniam.
Re: Does setSelection(index) on a grid invoke the selectionListener attached to it? [message #587569 is a reply to message #46226] Fri, 11 January 2008 01:17 Go to previous message
Asha Subramaniam.
Previous Topic:[Grid] How to set RowHeaderWidth ?
Next Topic:Brainstorming: grid as a spreadsheet
Current Time: Mon Sep 01 03:28:14 EDT 2025
Powered by FUDForum. Page generated in 0.12271 seconds
