Home » Eclipse Projects » GEF » scrolling graphical viewer
scrolling graphical viewer [message #46144] Thu, 28 November 2002 20:40 Go to next message
Originally posted by: jayuen.alumni.uwaterloo.ca
Hi:
I was wondering how I can set up the ScrollingGraphicalViewer such that even
if there aren't any EditParts that are outside of the visible portion of the
viewer, I can still scroll? Currently, if I want to expand the drawing area
of my graphical editor, it seems like the only way I can do this is by
creating a new EditPart, dragging it outside of the viewing area, and then
releasing. Subsequently, the scrollbars appear and I am able to scroll to
the edit part.
I was hoping to be able to increase the size of the scrolling area without
necessarily having edit parts created. I noticed that one of the bug
reports (22873) refers to auto-scrolling the graphical viewer on a drag. I
guess the functionality I am seeking is similar except that the graphical
viewer is scrolled by simply clicking the scrollbar arrows.
Thanks for any help!
Jason
Re: scrolling graphical viewer [message #46176 is a reply to message #46144] Thu, 28 November 2002 21:25 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
How big is big enough? You could put a MarginBorder on the primary layer.
Actually, there already is one there with size of 5 pixels. This prevents
selection handles from causing scrollbar changes.
"Jason Yuen" <jayuen@alumni.uwaterloo.ca> wrote in message
news:as6gfj$msi$1@rogue.oti.com...
> Hi:
even
the
area
> the edit part.
I
> Jason
Re: scrolling graphical viewer [message #46206 is a reply to message #46176] Thu, 28 November 2002 23:40 Go to previous messageGo to next message
Hi Randy:
1. How big is big enough?
Well, I was hoping that the user could scroll infinitely in either
direction. In some drawing apps (like Visio), the user can keep scrolling
even though there aren't any glyphs in the area to which he is scrolling.
The more he clicks on the scroll arrow, the thinner the scroll bar gets.
Currently, it seems the scroll bar scrolls only once the user has placed a
glyph outside the boundaries of the viewer. Basically, I would like the
user to be able to "grow" the drawing area simply through scrolling.
I looked at some of the methods in the Viewport class and tried to invoke
setContentsTracksHeight(false) and setContentsTracksWidth(false) but to no
avail.. I also looked at the RangeModel interface but I suspect that I'm
barking up the wrong tree :).
2. Margin border
Forgive me for my ignorance but I'm not entirely sure how a MarginBorder
would allow for the behaviour that I'm looking for. I searched the GEF
code and the only margin borders that seem to be created are in the palette
edit parts and none with respect to the primary layer. If possible, could
you clarify this suggestion?
Thanks a lot for your help,
Jason
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:as6j64$nm5$1@rogue.oti.com...
> > Hi:
> even
> the
> area
then
to
> > the edit part.
without
> I
graphical
> > Jason
Re: scrolling graphical viewer [message #46234 is a reply to message #46206] Fri, 29 November 2002 09:29 Go to previous messageGo to next message
The canvas is represented with "freeform" figures. Freeform-figures are
"shrink-wrapped" containers around their children. So, if you take the
Rectangle that encompasses all children of the primary layer, the primary
layer is at least that big. I say at least, because after this rectangle is
found, it is expanded by the Border that is set on the FreeformLayer. So,
if the borders insets are 1000 pixels all around, the "shrink-wrapping" will
be 1000 pixels larger than the rectangle needed to encompass the children.
This will cause a certain of free scrolling.
I don't like Visio behavior. If you scroll way off the center of the
diagram, how do you get back? I guess if you have a ruler you might have a
clue as to where the origin is. Pretty soon you will be able to drag an item
infinitely (well, until 2^31) in the logic example. The feedback layer
causes the scrolling bounds to change, and we are about to implement
autoscroll, so as the diagram scrolls down, the feedback layer will continue
to push the bottom limit down further.
news:as6r0l$pv3$1@rogue.oti.com...
> Hi Randy:
> 2. Margin border
palette
could
> Jason
layer.
prevents
> > > Hi:
that
> > even
of
> > the
drawing
> > area
> then
scroll
> to
> > > the edit part.
> without
drag.
> > I
> graphical
> > > Jason
Re: scrolling graphical viewer [message #46264 is a reply to message #46234] Fri, 29 November 2002 11:32 Go to previous message
I see what you mean now with the border. I experimented a little bit with
padding the primary layer but it's not the greatest. I think the upcoming
auto-scroll will be the best.
Yeah, I was envisioning a canvas with a ruler so that the user could
re-locate himself. I was also thinking that if I add zoom capabilities
later on, it wouldn't be that bad to navigate a (potentially) very large
canvas
Anyhow. thanks for your help,
Jason
news:as7tkg$am4$1@rogue.oti.com...
is
will
item
continue
> > Hi Randy:
scrolling
scrolling.
a
the
invoke
no
> > 2. Margin border
> palette
> could
> > Jason
> layer.
> prevents
> > > > Hi:
> that
> > > even
portion
> of
> > > the
> drawing
> > > area
by
and
> > then
> scroll
> > to
> > > > the edit part.
> > without
bug
> drag.
> > > I
> > graphical
> > > > Jason
Previous Topic:Change the Container Size as the child size changed?
Next Topic:Single Model - Layered views
Current Time: Tue Jul 15 02:31:57 EDT 2025
Powered by FUDForum. Page generated in 0.08099 seconds
