emulating glass pane [message #456686] |
Mon, 06 June 2005 21:55 |
Originally posted by: tmchild.gmx.net
Hi All
I'm looking to write a very simple GUI designer using swt.
The JavaBean Development Kit (BDK) available here
http://java.sun.com/products/javabeans/software/bdk_download .html uses a
glass pane to draw boxes and handles around GUI components and to intercept
mouse events for manipulating those components.
The glass pane makes it much easier to write code for manipulating GUI
controls sitting 'behind' it - while still allowing those controls to be
drawn using the actual widgets.
Can anyone suggest how I can achieve a similar result using SWT?
I know there are several SWT GUI designers - and I assume that they use
actual SWT widgets in 'design mode' so it must be possible to do something
like a glass pane in SWT.
All help gratefully received.
Cheers
Terry Child
Re: emulating glass pane [message #456700 is a reply to message #456691] |
Tue, 07 June 2005 10:12 |
Originally posted by: terry.child.vixensoft.co.uk
Hi Konstantin
Thanks for the reply.
From looking at your web site it seems that you draw and layout everything
using your own code.
How do handle custom widgets?
You product is much more advanced than I need. I want to do something much
simpler and use the existing widgets and layout managers as much as
possible.
That's what I like about the BeanBox application - it lets you manipulate
actual live widgets.
I guess what I need is some sort of transparent canvas - if that's even
possible with SWT?
Cheers
Terry Child
"Konstantin Scheglov" <scheglov_ke@nlmk.ru> wrote in message
news:mbOocRyaFHA.2692@fairy.ao.nlmk...
> Terry Child:
>> something like a glass pane in SWT.
> No, we show screenshots on widgets on design canvas and use GEF to show
> handles.
> SY, Konstantin.
> Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: emulating glass pane [message #456715 is a reply to message #456702] |
Tue, 07 June 2005 13:31 |
Ah I get it!
I can use WM_PRINT to grab the layed out control images from an invisible
shell.
I even found some sample code here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=26095
I'll use GEF for adding handles as you suggested and that should be enough
for my small project.
Many thanks.
Terry Child
news:xTbWVu0aFHA.3996@fairy.ao.nlmk...
> Terry Child:
>> everything using your own code.
> No, we use layouts and controls that we see in source code.
> We instantiate them.
>> much simpler and use the existing widgets and layout managers as much as
>> possible.
> Under Win32 you can use WM_PRINT message to get screenshot of SWT
> controls.
>> possible with SWT?
> I think no.
>>>Terry Child:
>>> handles.
>>>SY, Konstantin.
> SY, Konstantin.
FUDForum. Page generated in 0.03793 seconds
