Home » Eclipse Projects » Technology Project and PMC » Eclipse 64 bit support
Eclipse 64 bit support [message #46121] Thu, 13 February 2003 13:56 Go to next message
IBM has announced its support of Intel's new Itanium 2 processor and
revealed plans to later this year introduce an IBM xSeries system with
Itanium 2 processors.
IBM software -- such as WebSphere and DB2 -- also will support the Itanium
2 processor.
Does this implies there is a 64 bit version of Eclipse up and runing on 64
bit worlds? If so where can I get it.
-Carl
Re: Eclipse 64 bit support [message #46213 is a reply to message #46121] Sun, 16 February 2003 23:13 Go to previous messageGo to next message
Originally posted by: maildump.pacbell.net
I don't think there's a 64 bit version of any java application because they
fixed the size of all primitive data types - hopefully this does not create
a severe performance problem when upgrading to a double-wide. Just install
the SDK for 64-bit Intel machines and you are good to go with any java
application including Eclipse. Scroll down to the 64 bit install of your
choice (e.g., Itanium Windows)
http://java.sun.com/j2se/1.4.1/download.html
"Carl Wong" <carl.wong@intel.com> wrote in message
news:b2gpo4$fai$1@rogue.oti.com...
> 2 processor.
> -Carl
Re: Eclipse 64 bit support [message #46304 is a reply to message #46213] Tue, 18 February 2003 13:00 Go to previous messageGo to next message
> > 2 processor.
> > -Carl
I have already tried it on 64 bit Windows and it worked fine but real slow
on start up. I am more interest on Linux-64. The Java sdk seems to work
on Linux-64 (Redhat), but failed when I try Eclipse. Have anyone else try
it on Linux-64?
-Carl
Re: Eclipse 64 bit support [message #48032 is a reply to message #46304] Tue, 04 March 2003 07:01 Go to previous message
Originally posted by: beus.judi-interactive.de
which os (swt) version of eclipse you
Re: Eclipse 64 bit support [message #590348 is a reply to message #46121] Sun, 16 February 2003 23:13 Go to previous message
> 2 processor.
> -Carl
Re: Eclipse 64 bit support [message #590394 is a reply to message #46213] Tue, 18 February 2003 13:00 Go to previous message
> > 2 processor.
> > -Carl
it on Linux-64?
-Carl
Re: Eclipse 64 bit support [message #591243 is a reply to message #46304] Tue, 04 March 2003 07:01 Go to previous message
Previous Topic:Help. How can i use JDK 1.4.1_02 in enclipse
Next Topic:What happened to "Add to surrounding catch block"?
Current Time: Fri Jul 18 03:02:54 EDT 2025
Powered by FUDForum. Page generated in 0.11250 seconds
