Re: Eclipse 64 bit support [message #46213 is a reply to message #46121] |
Mon, 17 February 2003 04:13 |
Originally posted by: maildump.pacbell.net
I don't think there's a 64 bit version of any java application because they
fixed the size of all primitive data types - hopefully this does not create
a severe performance problem when upgrading to a double-wide. Just install
the SDK for 64-bit Intel machines and you are good to go with any java
application including Eclipse. Scroll down to the 64 bit install of your
choice (e.g., Itanium Windows)
http://java.sun.com/j2se/1.4.1/download.html
"Carl Wong" <carl.wong@intel.com> wrote in message
news:b2gpo4$fai$1@rogue.oti.com...
> IBM has announced its support of Intel's new Itanium 2 processor and
> revealed plans to later this year introduce an IBM xSeries system with
> Itanium 2 processors.
> IBM software -- such as WebSphere and DB2 -- also will support the Itanium
> 2 processor.
> Does this implies there is a 64 bit version of Eclipse up and runing on 64
> bit worlds? If so where can I get it.
> -Carl
Re: Eclipse 64 bit support [message #590348 is a reply to message #46121] |
> 2 processor.
> -Carl
FUDForum. Page generated in 0.04450 seconds
