Home » Modeling » TMF (Xtext) » How to add checks to a grammar?
How to add checks to a grammar? [message #46116] Fri, 29 May 2009 04:37 Go to next message
where do I have to place .chk files for grammars with TMF Xtext? Are there
any naming convetions for the files?
I placed them in the same folder as xtext grammar file. But the editor
seems not to recognize the checks.
Christoph
Re: How to add checks to a grammar? [message #46146 is a reply to message #46116] Fri, 29 May 2009 04:47 Go to previous message
if you want to use check for validation you should add the CheckFragment
to your *.mwe configuration like so:
<fragment class="org.eclipse.xtext.generator.validation.CheckFragment "/>
This will generate three *.chkl files :
- fast checks (evaluated live in the editor)
- normal checks (evaluated on save)
- expensive checks (evaluated through an explicit action)
The guice configuration is as well generated.
Sven
Christoph Kulla schrieb:
> there any naming convetions for the files?
> Regards
> Christoph
Previous Topic:from BNF to metamodel
Next Topic:[XText] problem in importing a metamodel.
Current Time: Sat Jul 05 05:53:40 EDT 2025
Powered by FUDForum. Page generated in 0.03566 seconds
