Home » Eclipse Projects » Mylyn » How to support RepositoryAttachementEditorInput
How to support RepositoryAttachementEditorInput [message #46099] Thu, 27 March 2008 12:23 Go to next message
How can I support Mylyn's RepositoryAttachementEditorInput in a custom
editor ? (This input is used to open an attached file in a task)
My editor can open an IFileEditorInput.
Do I need to explicitly support RepositoryAttachementEditorInput or can
it be adapted to another input type using getAdaptable() ?
Nicolas
Re: How to support RepositoryAttachementEditorInput [message #46130 is a reply to message #46099] Thu, 27 March 2008 12:46 Go to previous messageGo to next message
> can it be adapted to another input type using getAdaptable() ?
Nicolas, I would strongly recommend to use IStorageEditorInput as a
base interface for any custom editor inputs. In that case you would be
able to work with content that is not represented with local files or
resources (that include stuff from task attachments and also from
version control systems, like things you can open from CVS Repositories
or History views). RepositoryAttachmentEditorInput implements
IStorageEditorInput.
regards,
Eugene
Re: How to support RepositoryAttachementEditorInput [message #46191 is a reply to message #46130] Thu, 27 March 2008 16:09 Go to previous message
Thanks, I switched to IStorageEditorInput, and it worked.
Nicolas
> regards,
> Eugene
Re: How to support RepositoryAttachementEditorInput [message #588720 is a reply to message #46099] Thu, 27 March 2008 12:46 Go to previous message
regards,
Eugene
Re: How to support RepositoryAttachementEditorInput [message #588743 is a reply to message #46130] Thu, 27 March 2008 16:09 Go to previous message
Nicolas
> regards,
> Eugene
Previous Topic:Large refactoring
Next Topic:JIRA custom attributes
Current Time: Fri Jul 11 21:43:16 EDT 2025
Powered by FUDForum. Page generated in 0.03219 seconds
