How to support RepositoryAttachementEditorInput [message #46099] |
Thu, 27 March 2008 12:23  |
How can I support Mylyn's RepositoryAttachementEditorInput in a custom
editor ? (This input is used to open an attached file in a task)
My editor can open an IFileEditorInput.
Do I need to explicitly support RepositoryAttachementEditorInput or can
it be adapted to another input type using getAdaptable() ?
Nicolas
Re: How to support RepositoryAttachementEditorInput [message #46191 is a reply to message #46130] |
Thu, 27 March 2008 16:09  |
Thanks, I switched to IStorageEditorInput, and it worked.
Nicolas
>> can it be adapted to another input type using getAdaptable() ?
> Nicolas, I would strongly recommend to use IStorageEditorInput as a
> base interface for any custom editor inputs. In that case you would be
> able to work with content that is not represented with local files or
> resources (that include stuff from task attachments and also from
> version control systems, like things you can open from CVS Repositories
> or History views). RepositoryAttachmentEditorInput implements
> IStorageEditorInput.
> regards,
> Eugene
Re: How to support RepositoryAttachementEditorInput [message #588720 is a reply to message #46099] |
Thu, 27 March 2008 12:46  |
regards,
Eugene
Re: How to support RepositoryAttachementEditorInput [message #588743 is a reply to message #46130] |
Nicolas
> regards,
> Eugene
FUDForum. Page generated in 0.10885 seconds
