Home » Archived » Test and Performance Tools Platform (TPTP) » Support for automated UI tests available?
Support for automated UI tests available? [message #4027] Thu, 27 January 2005 05:18 Go to next message
I am developing Eclipse plugins. Is there any support for automated testing
of Eclipse UI or UI elements available or planned (something like start
action A which should bring up UI element B, fill field C with some text,
press Button D then which brings up UI element E, check if field E is filled
with text F etc...)? Ideal would be the possibility of having some test
scripts shich would also allow incorporating test code in specific places.
Richard
Re: Support for automated UI tests available? [message #10185 is a reply to message #4027] Fri, 11 March 2005 18:04 Go to previous message
Richard Birenheide Thu, 27 Jan 2005 11:18:33 +0100
> testing of Eclipse UI or UI elements available or planned (something
> like start action A which should bring up UI element B, fill field C
> with some text, press Button D then which brings up UI element E,
> check if field E is filled with text F etc...)?
Hopefully you have already found better answers to this, but JIC: take
a look at
http://www.eclipse.org/tptp/home/project_info/featureplans/f eatures.php?source=All&project=All&release=4.0&f ile=TPTPFeatures_4.xml
>> Bugzilla# Component Priority <snip> In Plan Summary
>> 74791 Test.UI.JUnit P1 <snip> Committed Support for
JUnit derivative projects such as HTTP Unit, Cactus, Abbot, etc.
http://bugs.eclipse.org/bugs/show_bug.cgi?id=74791
http://sourceforge.net/projects/abbot
Previous Topic:Profiling with BEA weblogic
Next Topic:possibility to use Hyades/TPTP for testing Eclipse plug-ins?
Current Time: Mon Jul 21 21:12:57 EDT 2025
Powered by FUDForum. Page generated in 0.03828 seconds
