Home » Archived » Test and Performance Tools Platform (TPTP) » Error generating report. GENERATE_ERROR
Error generating report. GENERATE_ERROR [message #46016] Mon, 12 December 2005 04:29 Go to next message
Generating a report (htm, csv or xml) I get the message :
" GENERATE_ERROR_For input string "0,000650" "
in an eclipse pop up window W_ERROR.
Re: Error generating report. GENERATE_ERROR [message #46043 is a reply to message #46016] Mon, 12 December 2005 13:54 Go to previous message
Originally posted by: Navid_Mehregani_nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 0067D5FE852570D5_=
Content-Type: text/plain; charset="US-ASCII"
I just generated HTML, XML, and CSV reports on a simple trace and it woked
fine. There could be something in your profiling data that the report
generators don't like. Why don't you profile to a file and attach your
trcxml file here so I can give it a try. To profile to a file, do the
following -> in your launch configuration, click on the profiling tab ->
click on the destination sub-tab -> select 'Send profiling data to a file'
-> specify a file with extension .trcxml -> profile.
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">I just generated HTML, XML, and CSV
reports on a simple trace and it woked fine. &nbsp;There could be something
in your profiling data that the report generators don't like. &nbsp;Why
don't you profile to a file and attach your trcxml file here so I can give
it a try. &nbsp;To profile to a file, do the following -&gt; in your launch
configuration, click on the profiling tab -&gt; click on the destination
sub-tab -&gt; select 'Send profiling data to a file' -&gt; specify a file
with extension .trcxml -&gt; profile.</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 0067D5FE852570D5_=--
Previous Topic:Profiling Menu disabled
Next Topic:profiling a webapp eat's up 100% CPU and slows down the AUT
Current Time: Sun Jun 08 00:50:31 EDT 2025
Powered by FUDForum. Page generated in 0.03773 seconds
