Home » Language IDEs » C / C++ IDE (CDT) » Debugging with Cygwin GDB
Debugging with Cygwin GDB [message #46014] Mon, 21 October 2002 07:58 Go to next message
Originally posted by: ijmuiden.pointbreak.biz
I'm having a problem using the CDT integrated debugging features under
Windows/Cygwin. Instead of getting a debugging perspective, I get the
standard user interface of the gdb debugger, since under Cygwin, gdb is
installed to launch a user interface (instead of running in console mode) by
default. This can be turned of by using the -nw option, but Eclipse doesn't
seem to use that option, and I can not find a dialog/window in Eclipse to
make it use that option.
Consequently, Eclipse gives me a timeout when starting the debugger (can not
set initial breakpoints), since it can not communicate with the user
interface, and I find the following in the log files:
!ENTRY org.eclipse.cdt.debug.core 4 5010 okt 21, 2002 13:43:47.898
!MESSAGE org.eclipse.cdt.debug.core.cdi.CDIException:
org.eclipse.cdt.debug.mi.core.MIException: Timedout occurred setting
temporary breakpoint.
!STACK 0
org.eclipse.cdt.debug.mi.core.cdi.BreakpointManager.setLocat ionBreakpoint(Br
eakpointManager.java:293)
org.eclipse.cdt.debug.core.CDebugModel.newDebugTarget(CDebug Model.java:115)
org.eclipse.cdt.launch.internal.LocalCLaunchConfigurationDel egate.launch(Loc
alCLaunchConfigurationDelegate.java:118)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfigurati
on.java:136)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationDialog
$10.run(LaunchConfigurationDialog.java:2299)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext
..java:98)
Is there anybody who knows how to make Eclipse bypass the user interface of
gdb? Any help is appreciated.
Gerjon
Re: Debugging with Cygwin GDB [message #46044 is a reply to message #46014] Mon, 21 October 2002 10:45 Go to previous messageGo to next message
Your situation is very strange. Try to look at
org.eclipse.cdt.debug.mi.core.MIPlugin.java. If you find CreateCSession
function there you can see string looks approximately like
args = new String[] {gdb, "-q", "-nw", "-tty", pty.getSlaveName(), "-i",
"mi1", program};
or like
args = new String[] {gdb, "-q", "-nw", "-i", "mi1", program};
As we can see options of gdb starting define in this strings. Try to
change it somehow.
Hope it help,
Igor S. Zamyatin
Interstron Ltd.
email: isz@interstron.ru
tel: +7 (095) 269-4713
cell: +7 (902) 659-5838
www: http://www.interstron.ru
> !STACK 0
> at
> at
> at
> at
> on.java:136)
> at
> at
> ..java:98)
> Gerjon
Re: Debugging with Cygwin GDB [message #46375 is a reply to message #46044] Tue, 22 October 2002 12:32 Go to previous message
Thanks for your response. I see that the version of CDT I'm using does not
use the "-nw" parameter; I'll update.
"Igor S. Zamyatin" <isz@interstron.ru> schreef in bericht
news:ap13uo$u9p$1@rogue.oti.com...
> "mi1", program};
> or like
> change it somehow.
> Hope it help,
> Igor S. Zamyatin
> Interstron Ltd.
mode) by
doesn't
to
not
> > !STACK 0
> > at
> > at
> > at
> > at
> > on.java:136)
> > at
> > at
> > ..java:98)
of
> > Gerjon
Previous Topic:extending C editor?
Next Topic:Visual c++
Current Time: Sun Jun 08 04:02:23 EDT 2025
Powered by FUDForum. Page generated in 0.04096 seconds
