Home » Archived » BIRT » Error1:Cannot open connection (jdbc) in Report Design /Preview
Error1:Cannot open connection (jdbc) in Report Design /Preview [message #46008] Tue, 14 June 2005 19:46 Go to next message
Originally posted by: skr1.charter.net
When I use the Report Design /Preview tab to view a very simple report I get
no data and the following error in the report:
There are errors on the report page:
Error1:Cannot open the connection for the driver (jdbc).
The report Data Source is using an oracle.jdbc.driver.OracleDriver (1.0)
driver class from
....\eclipse\plugins\org.eclipse.birt.report.data.oda.jdbc_0 .0.1\drivers\ojdbc14.jar
to connect to an Oracle 8.1.7 database.
Edit Data Source /Test Connection returns "Connection Successful".
Edit Data Set /Query shows all database tables and table columns. I dragged
the table columns into the Select clause and tables into to the From clause
in the query from the Available Items.
Edit Data Set /Preview Results returns the correct results set.
Could someone help get me past this error?
- Steve
Re: Error1:Cannot open connection (jdbc) in Report Design /Preview [message #46173 is a reply to message #46008] Wed, 15 June 2005 03:28 Go to previous messageGo to next message
Originally posted by: juergen.schwarz.gefasoft.de
Check that the .jar files (ojdbc14.jar) for your JDBC driver are also
present in the directory:
\eclipse\plugins\org.eclipse.birt.report.viewer_1.0.0\birt\W EB-INF\plugins\org.eclipse.birt.report.data.oda.jdbc\drivers
If not, copy it to this location. The Preview uses that directory while
the DataSet/Query uses another location...
> driver class from
> ...\eclipse\plugins\org.eclipse.birt.report.data.oda.jdbc_0. 0.1\drivers\ojdbc14.jar
> - Steve
Re: Error1:Cannot open connection (jdbc) in Report Design /Preview [message #46904 is a reply to message #46173] Wed, 15 June 2005 23:24 Go to previous message
That fixes it. Thank you.
"Juergen Schwarz" <juergen.schwarz@gefasoft.de> wrote in message
news:d8olbp$s90$1@news.eclipse.org...
>> get
>> driver class from
>> dragged
>> clause
>> Thanks,
>> - Steve
Previous Topic:memroy leak not detected/memory profiler stopping?
Next Topic:BIRT Integration
Current Time: Tue Jul 15 01:06:44 EDT 2025
Powered by FUDForum. Page generated in 0.05355 seconds
