Print menu item grayed out [message #45943] |
Sun, 03 April 2005 08:50  |
Originally posted by: lindelof.ieee.org
Hello all,
I have installed Eclipse 3.0 in my home directory. No matter what I do or
try, the "Print" menu item is permanently grayed out and I cannot print
out any source code. I use CUPS under Mandrake 10.0.
Has anyone any idea what I am doing wrong?
David
Re: Print menu item grayed out [message #48263 is a reply to message #46045] |
Wed, 06 April 2005 16:00  |
Had the same problem - then a kind soul pointed me towards Xprint
http://xpring.mozdev.org
(or something similar, just do 'xprint' on Google)
it worked - to a point :-)
No longer the menu is grayed out, and I can... well print: what I get
when sending to the printer a file from Eclipse, all I get are 50+point
font, which means that little more than a few charachter per page.
There is no way to set-up properties or to choose print fonts in Eclipse
that I can find - and this is a problem only with Eclipse - anything
else (from humble gedit, to Mozilla) prints correctly on the printer.
Most frustrating, and definitely a `bug' in my book!
Platform: Fedora Core 1 (kernel 2.4.18)
xprint-2004-07-07-release_009_001-0.9.001.i386
Eclipse 3.0.1 (but same problem with 3.0.2)
Any suggestions are most welcome!
Jeff Myers wrote:
> David,
> Please see
> http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/faq.html#printOnGTK
> Hope this helps,
> - Jeff
> David Lindelof wrote:
>> Hello all,
>> or try, the "Print" menu item is permanently grayed out and I cannot
>> print out any source code. I use CUPS under Mandrake 10.0.
>> Thanks,
>> David
FUDForum. Page generated in 0.11135 seconds
