Home » Archived » OHF » ProvideAndRegisterDocumentSetType --> OMElement
ProvideAndRegisterDocumentSetType --> OMElement [message #45932] Tue, 19 August 2008 09:00 Go to next message
Hi Everybody!
I have a very basic question - at least I hope it is basic ;) - that is
bothering me for days now!
I have metadata - received by an ITI-15 request - in form of an
ProvideAndRegisterDocumentSetType. Now I am changing and adding some
specific attributes. As an example - just for testing - I am trying to
add a XDSDocumentEntry.size to every DocumentEntryType with a simple loop
like:
for (DocumentEntryType documentEntry :
(EList<DocumentEntryType>)xdsMetadata.getDocumentEntry()) {
documentEntry.setSize("123456");
Now my problem is, that I want to send this "modified" metadata to an IHE
Registry using ITI-14.
Therefore I have to convert this metadata
-ProvideAndRegisterDocumentSetType - to an OMElement.
But I am really stuck on how to solve this problem.
I hope someone can help me!
Thanks in Advance for both your time and your knowledge!
Greetings
Stefan
Re: ProvideAndRegisterDocumentSetType --> OMElement [message #46040 is a reply to message #45932] Tue, 19 August 2008 15:44 Go to previous messageGo to next message
Hi Stefan,
Indeed this is --- kinda simple. So, one thing to start with is - when
sending the payload to the registry from a repository, you will need to
convert from the ProvideAndRegisterDocumentSetType back to an ebXML
SubmitObjectsRequestType. Once you're back into that type, then you can
submit to the repository.
The way we handle this in the XDS Source and XDS Consumer is
straightforward. In general, it requires three things:
1. Convert the ProvideAndRegisterDocumentSetType (XDS) object to
SubmitObjectsRequestType (ebXML) object
2. Convert the EMF-created SubmitObjectsRequestType object to a DOM object
3. Convert the DOM object to OM for use with Axis2.
Converting from ProvideAndRegisterDocumentSetType (XDS) object to
For XDS.a:
EbXML_2_1ProvideAndRegisterDocumentSetTransformer setTransformer = new
EbXML_2_1ProvideAndRegisterDocumentSetTransformer();
setTransformer.transform(prDocumentSetTypeObject);
SubmitObjectsRequestType submitObjectsRequest =
setTransformer.getSubmitReq()
For XDS.b:
EbXML_3_0ProvideAndRegisterDocumentSetTransformer setTransformer = new
EbXML_3_0ProvideAndRegisterDocumentSetTransformer();
Converting from EMF to DOM
This conversion requires the creation of an empty DOM Document and then
using the EMF XMLResource's "save" method to save EMF to DOM. Code
snippet looks something like this:
// Create DOM Document Instance
DocumentBuilderFactory factory = DocumentBuilderFactory.newInstance();
factory.setNamespaceAware(true);
DocumentBuilder builder = factory.newDocumentBuilder();
org.w3c.dom.Document domDocument = builder.newDocument();
// Convert / "save" EMF to DOM
RegistryPackage packageInstance = RegistryPackage.eINSTANCE;
DocumentRoot root = RegistryFactory.eINSTANCE.createDocumentRoot();
root.setSubmitObjectsRequest(submitObjectsRequest);
XMLResource resource = (XMLResource)(new
RegistryResourceFactoryImpl()).createResource(URI.createURI( RegistryPackage.eNS_URI));
resource.getContents().add(root);
resource.save(domDocument, new HashMap(), new DefaultDOMHandlerImpl());
resource.unload();
Element domElement = domDocument.getDocumentElement();
Converting from DOM to OM
Apache Axis provides a utility to convert from DOM to OM (and back).
Use this:
OMElement omElement = org.apache.axis2.util.XMLUtils.toOM(domElement);
The P&R element should now be "sendable" over the wire.
I put this together pretty fast, so I'm sure I missed something, but
might give it a try!
-Matt
Stefan S. wrote:
> Hi Everybody!
> loop like:
> IHE Registry using ITI-14.
> Greetings
> Stefan
Re: ProvideAndRegisterDocumentSetType --> OMElement [message #46101 is a reply to message #46040] Wed, 20 August 2008 01:43 Go to previous messageGo to next message
Hi Matt!
Thanks for your answer.
Indeed it is very simple, if you know how to do it! ;)
Greetings
Stefan
Re: ProvideAndRegisterDocumentSetType --> OMElement [message #46131 is a reply to message #46101] Wed, 20 August 2008 03:12 Go to previous messageGo to next message
Hi Matt!
After examining your code fragment in detail I stumbled across the
following "problem" and would like to present my solution, just in case
someone experiences the same problem.
The presented example contains the following:
The "problem" is, that the class/interface DocumentRoot -
org.eclipse.ohf.ihe.common.ebxml._3._0.rs.DocumentRoot - as returned by
RegistryFactory.eINSTANCE.createDocumentRoot() does not contain a method
"setSubmitObjectsRequest".
My "solution" - or approach - is to use the method "setRegisterRequest()",
as shown in the lines below:
org.eclipse.ohf.ihe.common.ebxml._3._0.rs.DocumentRoot root =
root.setRegistryRequest(submitObjectsRequest);
It seems to work, so I think the "problem" is saved. Thanks again for your
help!
Greetings
Stefan
Re: ProvideAndRegisterDocumentSetType --> OMElement [message #46342 is a reply to message #46131] Wed, 20 August 2008 21:24 Go to previous message
Ah - good catch! I shouldn't have been as ambiguous with those Java
package names. Thanks for the clarification!
-Matt
Stefan S. wrote:
> Hi Matt!
> "setRegisterRequest()", as shown in the lines below:
> your help!
> Greetings
> Stefan
Re: ProvideAndRegisterDocumentSetType --> OMElement [message #586885 is a reply to message #45932] Tue, 19 August 2008 15:44 Go to previous message
Hi Stefan,
For XDS.a:
For XDS.b:
resource.unload();
Use this:
-Matt
Stefan S. wrote:
> Hi Everybody!
> loop like:
> Greetings
> Stefan
Re: ProvideAndRegisterDocumentSetType --> OMElement [message #586911 is a reply to message #46040] Wed, 20 August 2008 01:43 Go to previous message
Hi Matt!
Greetings
Stefan
Re: ProvideAndRegisterDocumentSetType --> OMElement [message #586921 is a reply to message #46101] Wed, 20 August 2008 03:12 Go to previous message
Hi Matt!
help!
Greetings
Stefan
Re: ProvideAndRegisterDocumentSetType --> OMElement [message #587006 is a reply to message #46131] Wed, 20 August 2008 21:24 Go to previous message
-Matt
Stefan S. wrote:
> Hi Matt!
> your help!
> Greetings
> Stefan
Previous Topic:Query Document Failure using the OHF
Next Topic:ITI-14 - RetrieveDocument URI (Length Problem)
Current Time: Sun Jul 27 01:29:45 EDT 2025
Powered by FUDForum. Page generated in 0.04702 seconds
