Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » OCL Tuple Problem
OCL Tuple Problem [message #45902] |
Tue, 22 August 2006 03:17  |
OK this is a little bit complex:
In the oclconsole I have to evaluate Methods:
One can evaluate only one expression, and the other can evaluate defines
and expressions.
I evaluate the following to statements:
define:
theCompoundQuery(InfC:Set(Information), LToolC:Set(LogicalTool)) :
Set(Tuple(
i : Information,
lt: LogicalTool,
r : Boolean )) =
InfC->collect( info:Information | LToolC->collect(
ltool:LogicalTool |
Tuple {
i : Information = info,
lt: LogicalTool = ltool,
r : Boolean = theCheck(info, ltool)
}))->asSet()
expression:
theCompoundQuery(self.informations,self.logicalTools)->asOrderedSet()- >at(1).i
My problem:
theCompoundQuery returns Tuples like
Tuple{i = Information XDF, lt = Paper Based System PN, r = false}
Tuple{i = Information XLI, lt = Paper Based System PN, r = true}
Tuple{i = Information XDF, lt = IT Base System PACS, r = false}
so the expression takes the first Tuple and returns the information.
My problem, if I use my method which adds the definition to the
IOCLHelper, everything works fine.
But if I use only the method for the expression, i get the following error:
The feature 'i' is not a valid feature
But if I evaluate:
I get the Tuples?
Chris
Re: OCL Tuple Problem [message #47930 is a reply to message #45902] |
Wed, 30 August 2006 09:22  |
Hi, Chris,
I looks like the TupleType defined when your operation definition was parsed
is a distinct from (though similar to) the TupleType defined when your
query expression was parsed.
If these were parsed in the same Environment, the the same TypeResolver
would have been used to define the TupleType, so you would end up with only
one TupleType and this should work. Otherwise, two different Environments
will have two different TupleTypes.
If you are using a single environment, then this would be a bug, in which
case could you please raise a Bugzilla?
Christian
> and expressions.
> define:
> Set(Tuple(
> i : Information,
> lt: LogicalTool,
> r : Boolean )) =
> ltool:LogicalTool |
> Tuple {
> }))->asSet()
> expression:
> My problem:
> error: The feature 'i' is not a valid feature
> But if I evaluate:
> I get the Tuples?
> Chris
Re: OCL Tuple Problem [message #586910 is a reply to message #45902] |
Hi, Chris,
Christian
> and expressions.
> define:
> Set(Tuple(
> i : Information,
> lt: LogicalTool,
> r : Boolean )) =
> ltool:LogicalTool |
> Tuple {
> }))->asSet()
> expression:
> My problem:
> But if I evaluate:
> I get the Tuples?
> Chris
Current Time: Tue Jul 22 19:08:37 EDT 2025
Powered by FUDForum. Page generated in 0.04821 seconds
