Home » Archived » M2M (model-to-model transformation) » [ATL] run Atl transfomation by program with eclipse 3.3
[ATL] run Atl transfomation by program with eclipse 3.3 [message #45898] Wed, 13 June 2007 05:21 Go to next message
When I run an ATL transformation with a Main program, I have the following
exception:
java.lang.RuntimeException: java.lang.NoClassDefFoundError:
org/eclipse/core/runtime/CoreExceptionjava.lang.RuntimeExcep tion:
java.lang.NoClassDefFoundError: org/eclipse/core/runtime/CoreException
at ujf.verimag.bip.transfo.Main.getDefaultHandler(Main.java:76)
at ujf.verimag.bip.transfo.Main.addInputModel(Main.java:201)
at ujf.verimag.bip.transfo.Main.parseArgs(Main.java:157)
at ujf.verimag.bip.transfo.Main.main(Main.java:86)
Caused by: java.lang.NoClassDefFoundError:
at ujf.verimag.bip.transfo.Main.getDefaultHandler(Main.java:70)
... 3 more
Usage: <this program> --trans <transformation url> [--in <id>=<model>
<id>=<metamodel> <MDR|EMF>] [--out <id>=<model> <id>=<metamodel>
<MDR|EMF>] [--lib <id>=<library url>] --next --trans ...
This Main works with Eclipse 3.1, and when I look in the
org.eclipse.core.runtime_3.3.100.v20070319.jar and
org.eclipse.core.runtime.compatibility_3.1.100.v20070319.jar
I dont find the CoreException class.
Do I need to import other library for this class?
Thanks for your help,
Anne.
Re: [ATL] run Atl transfomation by program with eclipse 3.3 [message #45999 is a reply to message #45898] Wed, 13 June 2007 07:40 Go to previous messageGo to next message
Anne Robert schreef:
Hi Anne,
> following exception:
> ... 3 more
You guessed it ;-). CoreException has been moved to Equinox Common
(org.eclipse.equinox.common_*.jar) since Eclipse 3.2. Check out the
following Ant script that attempts to gather all jar dependencies:
http://ssel.vub.ac.be/viewcvs/viewcvs.py/UML1CaseStudies/uml 1cs-atlcommandline/lib/copydep.build.xml?view=markup
> Anne.
You're welcome ;-)
Dennis
Re: [ATL] run Atl transfomation by program with eclipse 3.3 [message #46028 is a reply to message #45898] Wed, 13 June 2007 09:18 Go to previous message
Thank you, it works fine now.
Anne.
Previous Topic:[ATL] One more problem in running Main.java written by Dennis
Next Topic:[ATL] execution different between "plugin" and standalone
Current Time: Sat May 10 08:43:07 EDT 2025
Powered by FUDForum. Page generated in 0.03839 seconds
