[XText] Outline is slow on scrolling [message #45880] |
Thu, 28 May 2009 12:03  |
Extending a node with 400 leafs and scrolling after is very slow. For
10000+ is almost unusable.
It seems there is a problem with the TreeViewer using SWT.VIRTUAL on
Windows systems.
See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=129457
https://bugs.eclipse.org/bugs/show_bug.cgi?id=200214
Is there a reason to use virtual tree viewer?
My workaround was to use a normal ITreeContentProvider and remove the
SWT.VIRTUAL.
Scrolling is nice. Creation of all content outline for 10000+ nodes is not
too slow. It seems better then the lazy implementation.
Anyway, I think we should allow the user to set or not the SWT.VIRTUAL
flag.
The problem is it's not too easy to do that without duplicating entire
classes from xtext code base.
My workaround:
1)Copy LazyTransformingTreeProvider to my sources and rename it to
Implements now ITreeContentProvider, not ILazyTreeContentProvider
2)Copy XtextContentOutlinePage to my sources
Replace:
private ILazyTreeProvider provider;
with
private TransformingTreeProvider provider;
3)XtextContentOutlinePage extends LazyVirtualContentOutlinePage which
privately constructs the TreeViewer with SWT.VIRTUAL
Copy also LazyVirtualContentOutlinePage to my sources, removing the
virtual flag
A lot of code is duplicated.
I need:
1) a way to specify in LazyVirtualContentOutlinePage if VIRTUAL flag
should be used or not
2) a way to inject in XtextContentOutlinePage a
ILazyTreeProvider(implementing ILazyTreeContentProvider) or a
INotLazyTreeProvider(implementing ITreeContentProvider)
Should I post a bug to bugzilla? And maybe a patch? Will this fix(if
done), make it to 0.7.0 release?
My solution is good for xtext?
Thank you,
Dan
Re: [Xtext] Outline is slow on scrolling [message #45939 is a reply to message #45880] |
Thu, 28 May 2009 12:40   |
Hi Dan,
please file a bugzilla and attach a patch. Please also provide a small
testcase that illustrates the issue.
Most likely we'll do something for Xtext 0.7.0 to improve the overall
experience with the outline.
Thanks in advance,
Sebastian
Am 28.05.2009 18:03 Uhr, schrieb Dan Stefanescu:
> Hello,
> Windows systems.
> See:
> SWT.VIRTUAL.
> not too slow. It seems better then the lazy implementation.
> flag.
> My workaround:
> Replace:
> with private TransformingTreeProvider provider;
> virtual flag
> I need:
> Thank you,
> Dan
FUDForum. Page generated in 0.03679 seconds
